Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 03-17-2007, 10:02 AM   #1
starflyte1
starflyte1's Avatar
Profile:  2007 25' Safari FB SE
Bonita Springs , Florida
Screwing into walls?
I think that I have read on this forum that you can use stainless metal screws to fasten things like curtain tracks and shelves to the wall of an AS.
How heavy does something need to be before you have to find a rib?
Can you remove a screw, or maybe it is a rivet, and use that hole to fasten something?
I would like to ad some curtain tracts or window side valances in our Safari SE.
Thanks for any replies!
Pat
starflyte1 is offline   Reply With Quote
Old 03-17-2007, 10:05 AM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Valances should be no problem for using two brackets with two rivets each (one bracket on each end). Just remember to use aluminum rivets to keep from experiencing dissimilar metal corrosion.
Change is inevitable, except from a vending machine
AIR#2611
Old 03-19-2007, 06:33 AM   #3
starflyte1
starflyte1's Avatar
Thanks again, Terry! Will use aluminum rivets. Pat
Zolatone walls Rob Upholstery, Blinds, Walls & Interior Finishes 18 02-06-2007 07:41 PM
sticky interior walls sovereign Upholstery, Blinds, Walls & Interior Finishes 54 05-30-2006 08:38 AM
Shower walls, what to do? myboyburt General Interior Topics 1 04-16-2004 03:54 PM
Shower stall walls 53flyingcloud Upholstery, Blinds, Walls & Interior Finishes 7 08-31-2002 11:38 AM
getting behind the walls... Chuck General Interior Topics 14 07-11-2002 12:20 PM
