Old 01-04-2010, 06:29 PM   #1
1974 27' Overlander
youngstown , Alberta
Send a message via Skype™ to tinlizzie69
rolling cupboards
does anyone know how to fix the rolling cupboards from coming apart the cabinets under the sink the are coming apart in sections when you roll them open.....
tinlizzie69 is offline   Reply With Quote
Old 01-04-2010, 06:42 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Not sure what you are talking about. Photos would help.
If you are referring to the galley sink cabinet. The plywood sides and shelves fit into extruded aluminum channels and are held in place with blind (pop) rivets. Sometimes the plywood rips out the rivet hole. Drill new holes and re-rivet. You could also use some "L" brackets to attach the shelves to the sides and the sides to the interior skin.
Old 01-04-2010, 07:04 PM   #3
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
Maybe you are talking about the tambour doors. Here's a link that may help.
http://www.airforums.com/forums/f38/...ors-17665.html
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 01-05-2010, 09:13 AM   #4
1974 27' Overlander
thanks everyone it is the rolling doors they come apart in strips...they dont roll open very well without coming apart
Old 01-05-2010, 12:35 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Tambour doors for sure. They are honery critters. They can be repaired or replaced. You should be able to find a bunch of info on the forums if you do a search. A lot of people have replaced them with solid panels. The ones under the sink are particularly pesky.
Old 01-22-2010, 10:47 PM   #6
1971 27' Overlander
Boulder City , Nevada
hey, tinlizzie69. We bought a '71 Overlander last year and, yes, as yours,the tambour doors under the sink area were falling apart. I pulled them out last summer (carefully, 'cause I thought I could maybe rebuild them). Lots of info on the forum about them. I think I would buy the new, if I were going to keep it original. At this point, I have spring-tension rods and fabric "drapes" for my doors. We've traveled NV to AK and haven't had a problem with stuff falling out of the shelves. I think I'll just keep them that way. Easy to access, for sure.
zigzag is offline   Reply With Quote
Old 01-28-2010, 10:40 AM   #7
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I had to replace all of the tambour doors in my '72 Sovereign. It's not hard to do at all. I ordered unstained replacement tambour off the net. Just cut them to size using the old one's as templates and stain them. My interior is walnut and I used a walnut stain. They match perfectly. See my blog for pics and details.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
rolling on new tires and axles aaumpine Axles 5 06-12-2009 10:01 AM
Thanks to all of you, we're rolling! Rosie39j Member Introductions 7 02-23-2006 07:07 AM
Rolling Shade in Door FlyFishInn Upholstery, Blinds, Walls & Interior Finishes 2 09-06-2005 10:31 AM
rolling airstream commercial wunderful62 Our Community 5 12-19-2003 09:03 PM
