Old 02-11-2013, 02:03 PM   #1
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Rivets Missing
I hope I am in correct forum. I am still a newbie and just discovered four missing rivets inside up and near the door. I tried search forum buttons, came up short. I am sure I am not looking in right place. So any direction would be helpful. I will order rivets from JC, and I guess a gun? Totally clueless, but willing to learn. Thank you. Sbb
Sbb is offline   Reply With Quote
Old 02-11-2013, 06:07 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Not quite sure what your question is. But, since these are interior rivets, they are pop rivets, and are not terribly unique. You can set them with a $5 pop rivet tool available from most hardware stores, and you can probably get rivets in small quantities there as well.
You will want to investigate what is causing the rivets to fail, and see if there is more extensive damage. Think wheel balance, axles, etc.
