Old 08-24-2004, 08:09 PM   #1
1963 19' Globetrotter
Moline , Illinois
Rivets and tools
I am currently in the process of removing an interior panel on my 63 globetrotter to fix a short in the wiring and will need to obtain the rivets to reattach it to the door frame. The people at Airstream tell me I need 3/8 or 1/2 length 1/8 dia. common bucked rivets. Need help on a rivet source and suggestions on tools. Any way to avoid the expense of a pneumatic rivet tool?
63air is offline   Reply With Quote
Old 08-24-2004, 08:12 PM   #2
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
They are common pop rivets available at any hardware store - they have rivet tools also
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 08-24-2004, 08:54 PM   #3
JohnG's Avatar
This is a good thread to read that contains a lot of information about rivet tools. http://www.airforums.com/forum...ad.php?t=13329
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-24-2004, 08:59 PM   #4
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
And they sell them in white, too, used in the inside. If you need white and can't find them at the store, don't give up, they exist, ask a local hardware store to order them or go online.
Oh, and i would recommend to pay the extra for the rivet tool, the hand squeeze one, that has the "swivel" head. I didn't and sometimes wish I had.
John
AYRSTRM2 is offline   Reply With Quote
Old 08-24-2004, 11:54 PM   #5
greg176's Avatar
Gabriola Island , British Columbia
those rivets on the door frame are common bucked rivets.For that many rivets with both ends exposed you can buck them using a hammer and a dolly.
greg176 is offline   Reply With Quote
Old 08-25-2004, 09:07 AM   #6
Images: 59
Greg,
Excellent point about the door openings in older models. Can't use Olympics, and pop rivets might stick out into the gasket area.
Also, how do you feel about using aluminum pop rivets with steel pins for the interior? They might be stronger, but they might cause corrosion of the aluminum, especially above the sink and in the bathroom. I think (but don't know for sure) that the factory used steel pin aluminum body rivets. I guess if they were painted they might be ok.
Old 08-25-2004, 09:25 AM   #7
Ken J's Avatar
Durango , Colorado
Images: 14
FWIW, I used steel pin pop rivets for several years with no probems - as far as I can tell from all the steel shanks I've found in the trailer - its what Airstream used.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Olympic rivet tools smallfry Ribs, Skins & Rivets 9 10-16-2014 05:37 PM
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
Rivets skip Ribs, Skins & Rivets 25 08-03-2003 10:46 AM
Rivets and tools art Ribs, Skins & Rivets 13 04-19-2003 05:58 PM
Drilling out rivets... Andy R Ribs, Skins & Rivets 2 04-13-2002 03:02 PM
