Old 10-12-2015, 12:06 PM   #1
1985 27' Sovereign
mckinney , Texas
Rivet Removal Tool OR Blind Rivet Removal T
I am needing to buy a rivet removal tool and sure enough.. i stumble upon 2 of them:
1) Aircraft Tool Supply Blind Rivet Removal Tool - $75.95 1341s
BLIND RIVET REMOVAL TOOL from Aircraft Tool Supply
2) Aircraft Tool Supply Rivet Removal Tool - $59.95 1341A
So! to blind or not to blind .. that is the question.
Which one is recommended to buy? Does the pricier one serve an additional purpose that the 1341A doesn't serve.
I am removing some interior of my airstream..
pics coming soon.
Miriam
mkamanu is offline   Reply With Quote
Old 10-12-2015, 12:38 PM   #2
1979 23' Safari
Wayland , New York
I've got the cheaper one. I think the difference is the more expensive one has serrated head to keep the rivet from spinning in place. The serrations can definitely help. Used it mostly for solid and Olympic rivet removal. Pop rivet removal is pretty easy with just a sharp drill bit centered in the mandrel hole of the rivet, except the times that the whole rivet spins.
Old 10-12-2015, 01:44 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
If you are only drilling out interior blind rivets, I wouldn't buy either of these tools. One practice that I found very helpful in taking out blind rivets is to get a spring-loaded center punch and give the (usually steel) mandrel of the rivet a good smack with it. This will drive the mandrel deep enough that you won't be struggling to keep the drill bit centered on the hardest part of the rivet (the steel mandrel). After that, just drill it out with a SHORT, sharp bit. Out of the hundreds of rivets I drilled out, I had very few that spun, and I usually found that poking them with a screwderiver was all that was needed.
good luck!
Old 10-12-2015, 07:29 PM   #4
1985 27' Sovereign
mckinney , Texas
Thanks y'all
I will give it a shot this weekend.
Best Blind Rivet? dbj216 Ribs, Skins & Rivets 2 02-15-2015 05:28 AM
Rivet removal tool campcollector Ribs, Skins & Rivets 18 07-25-2013 09:52 PM
Blind rivet question Smartstream General Repair Forum 2 07-23-2013 07:11 PM
Door Blind removal? bridor15 Upholstery, Blinds, Walls & Interior Finishes 1 01-26-2010 07:17 PM
