Old 12-10-2009, 03:29 PM   #1
1978 31' Sovereign
Rivet removal!
I've pulled out the closet and a few overhead compartments in my '78 Sovereign, which has left me with quite a few unsightly rivet holes and stems. I am going to be repainting the walls and need to cover these up and/or make them flush with the rest of the wall. My questions are 1) What can I use to make those stems flush with wall (clipping them off hasn't been working well)? and 2) Can I used regular spackle to fill in the holes? I will be using an oil-base primer and latex paint over it.
Thanks.
By the way, I don't want to put more rivets in. The pattern would be distracting.
eastbound is offline   Reply With Quote
Old 12-10-2009, 04:00 PM   #2
Images: 59
You need to do it just like sheetrock. Use a ballpeen hammer to make a depression, then sand off the paint, fill with bondo (not spackle), and sand it to match the surrounding surface.
Old 12-10-2009, 06:44 PM   #3
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
1954 22' Flying Cloud
Brussels , Wisconsin
Fill it with a Rivet
Use an Olympic rivet, sand it down or shave it. I think the the flexing and movement of the trailer any kind of filler will crack and fail.
I'm NOT an old man.............
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
Ed Emerick is offline   Reply With Quote
Old 12-10-2009, 06:53 PM   #4
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
There is a good chance that you unknowing also removed rivets that hold the inter skin to the ribs! I would replace all the rivets with pop rivets! They will look fine after paint, besides you have a aluminum trailer rivet are cool!
Todd
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 12-10-2009, 07:24 PM   #5
Images: 59
I haven't had a proper bondo job crack and fail yet, on things that flex more than a trailer. We're talking about repairs the size of a quarter, not a quarter panel.
Old 12-10-2009, 07:40 PM   #6
1999 25' Safari
Fairburn , Georgia
How would everyone feel if the airlines repaired their aluminum aircraft with bondo instead of rivets?? Would you feel safe?
The correct way to remove rivets is to drill them.
JackMac is offline   Reply With Quote
Old 12-10-2009, 08:25 PM   #7
Images: 59
Planning to fly your Airstream at 35,000 ft with a couple hundred passengers? We're talking about a cosmetic repair, hardly a critical life safety issue.
rivet, spackle, stem, hole
Rivet removal tool campcollector Ribs, Skins & Rivets 18 07-25-2013 10:52 PM
Rivet Removal Questions trout-fly Ribs, Skins & Rivets 9 11-25-2009 01:45 PM
Best drill for rivet removal? SilverHoot Ribs, Skins & Rivets 10 05-12-2009 10:44 PM
Rivet Removal Gasket Locating Maximo General Repair Forum 3 02-29-2008 11:44 PM
Rivet Removal pap Ribs, Skins & Rivets 11 02-06-2004 11:04 PM
