03-15-2016, 06:55 PM
2005 31' Classic
Garner,
, North Carolina
replacing existing fluorescent tubes with LED's
Most of the light in the 2005 we got has been converted to LED light except the fluorescent tubes lights.
Was looking at led strip light on a roll and see there are some number like 3528, 5050 and 5630.
In looking around it seem the higher the number the brighter the light per LED.
I was wondering if the 3528 strips when installed in the existing fixture with 2 to 3 strips would be enough light or would the 5050 led be the better choice in warm white or maybe the cool white color for living/ dining area.
what did you use and are you happy with them??
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
03-15-2016, 07:09 PM
1999 28' Excella
New Orleans
, Louisiana
I think I saw Out of Doors Mart has a conversion kit to change those fixtures to led.
03-15-2016, 07:15 PM
1976 29' Ambassador
Fitchburg
, Wisconsin
I like the 5050 in the warm white color. I'd use 3 or 4 strips the length of the fixture to get about the same brightness as the fluorescents give you.
Dennis
03-15-2016, 07:21 PM
Airstream Obsessed
2006 30' Classic
1989 29' Excella
Sandy
, Utah
I bought a few rolls of the 5050 warm white and they worked great in converting the fluorescents in my 2006 classic to LED. I only used one strip but looped it around one full time. Basically it amounts to 2 full strips and a half circle on the end opposite the power hookup. They work better than the fluorescent when it's cold.
03-15-2016, 07:25 PM
2002 19' Bambi
Lafayette
We used Illuminous T5 12" 12v LED tubes ( http://www.eversale.com/catalog2_1/p...-1030vdc-p-299) to replace the fluorescent tubes in our lamps. Our lamps happen to be a German import we installed years ago, but the fluorescent tubes in them were the standard T5 12" tubes. We had used both white and warm white in the fluorescents. The Illuminous are said to be "neutral white" and that color seems to be about halfway between the white and warm white of the fluorescents and the LEDs are somewhat brighter than the fluorescent tubes.
We certainly like them, but it was necessary to rewire the fixtures to bypass the electronic ballast. The LED tubes run straight off the 12v system.
Tim
03-15-2016, 07:37 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Would you mind posting a few photos, a list of materials, and some general instructions for what you did?
I've been looking at this video, trying to decide what to do to mine. I have 7 of these fixtures in my Excella.
03-15-2016, 08:17 PM
1999 34' Excella
Hillsboro
Made my own... From HitLights..5050's. 5000kelvin.... White.. Their 4000kelvin was
A tad more yellow.. Hardly noticeable difference. But the "lumens" they produce are Far greater than the cheaper ones.
We used 2, then 3... Settled on Four. Man do light up!! Also installed 4 strips under the stove hood of the 4000k. Momma like...
Peace and Blessings..
Channing
WBCCI# 30676
03-15-2016, 08:21 PM
Oswego
I also made my own, but I do not remember the temperature. I used warm in living areas and cool white over work areas like kitchen counter and a over fridge.
-Rich-
03-15-2016, 08:22 PM
1999 34' Excella
Hillsboro
Here is room shot
Channing
WBCCI# 30676
03-15-2016, 08:24 PM
1999 34' Excella
Hillsboro
Retry
Channing
WBCCI# 30676
03-15-2016, 08:26 PM
1999 34' Excella
Hillsboro
Drat
Try these folks... From Louisiana...
https://www.hitlights.com
Channing
WBCCI# 30676
03-16-2016, 06:41 AM
2005 31' Classic
Garner,
, North Carolina
Originally Posted by cwf
Retry
that what happens when you take picture when swinging for the rafters.. LOL
Carl, Raleigh NC
03-16-2016, 07:36 AM
Princeton
, New Jersey
Mine was a conversion of a 6 incandescent bulb fixture. Not sure of the temperature range of the LEDs I used, they weren't giving those numbers back then, but the conversion is quite easy and worked fine.
I used 3 strips for each side on the low power side of the switch and 2 more when the high side of the switch is on, total of 5 strips per side. If I were doing it again I would add another strip on both levels for some real punch.
Sorry but I did not take a picture of the larger fixtures when I did them.
On the smaller fixtures I drilled out the old sockets for room and a cleaner job.
2004 Excursion 4x4
03-16-2016, 08:04 AM
1999 34' Excella
Hillsboro
Busted!!! You can do that in this baby!!!
Channing
WBCCI# 30676
03-16-2016, 08:05 AM
1999 34' Excella
Hillsboro
That is clean, Howie!!!
Channing
WBCCI# 30676
03-16-2016, 10:49 AM
2013 30' Classic
Greenwood
, Mississippi
Retry
Why is your trailer upside down?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
03-16-2016, 12:10 PM
1997 31' Land Yacht
Mahone Bay
, Nova Scotia
We bought inexpensive warm white LED tape online, put in a loop covering the area where the tubes were. Works fine. Not quite as bright, but the tubes were too bright, can count on one hand how many times we put those ceiling lights on! Much nicer now. We also put warm white LED flat bulbs in 3 of the fixtures, can't tell the difference. If you want brighter ceiling fixtures, you could put in 3 strands instead of two.
03-16-2016, 04:08 PM
1999 34' Excella
Hillsboro
Guess I had it downside up to clean off the underbelly. 😜😜😜😜🙁😳
Channing
WBCCI# 30676
03-16-2016, 09:01 PM
texastex
1984 34' Excella
GARLAND
I used a roll of about 15 feet of bright LEDs some nylon zips and clear box shipping tape. I used a Coleman cold solder to attach wires at the cut marks when necessary. By using the bright LEDs I could just use one strip per fluorescent bulb and they worked very well. I did all three bulbs in the living area in about an hour most of that time was learning to use the solder properly. I have a 1984 34 foot Excella and it has porthole windows above the fixtures which the lights shine up when the portholes covers are open. The other fixture I did was in the bedroom which also has a vent fan I just basically put one string of LEDs in a squarish circle around where the fluorescent bulbs used to be. I also had 8 inch fixtures and they bathroom that I used the switch after removing the bulbs and ballasts mechanism, I used a circular motion of LED lights while incorporated the original switch. All the LED replacements work great and as other light fixtures die out on me I am replacing them with LEDs. Good luck in your transformations.
03-16-2016, 09:27 PM
Richard
2006 30' Classic S/O
Merced
Check this link out if you want to replace your tube light tubes with LED http://jirahled.com/ I used his LEDs in all my overhead tube lights. Easy to do. My 2006 Classic in now 100% LED
