Old 05-24-2015, 07:13 AM   #1
1989 32' Excella
Fort Benning , Georgia
Replaced gaucho with dinette
88 Excella 31'. Tons of fun, but need more lounging room. After poking around here for ideas, happened across pizzachop's build, and started buying wood.
Flooring is Trafficmaster Allure, Dark Walnut. Measured out where we wanted it and got to work. Couple of slots so it fits together, then measured for the back slats to drill in the rear support and hinges.
Name:	ImageUploadedByAirstream Forums1432469250.535931.jpg
Name:	ImageUploadedByAirstream Forums1432469490.899697.jpg
Cut in some supports for the corners, then cubbies for the front.
Name:	ImageUploadedByAirstream Forums1432469622.451260.jpg
Chatski is offline   Reply With Quote
Old 05-24-2015, 07:18 AM   #2
1989 32' Excella
So it needed a table. I ordered a telescoping pedestal support, but it needed to go under by six inches. I ended up cutting as far in to the floor and subfloor as I could, and cutting off the bottom of the inside pipe. It gives us JUST enough room to get in/out and enjoy a massive table/bed. Click image for larger version
Name:	ImageUploadedByAirstream Forums1432469811.722998.jpg
Name:	ImageUploadedByAirstream Forums1432469854.509888.jpg
Name:	ImageUploadedByAirstream Forums1432469901.547597.jpg
Maxwell approved.
Old 05-24-2015, 07:23 AM   #3
1989 32' Excella
Now what to do about cushions?
The dinette is 63"x90", so I ended up ordering a Cal King Foam RV/Truck bed off Amazon, and hacked it up with a kitchen knife. Quick upholstery job with some fabric from the local upholstery outlet ($27), and we're in business.
Name:	ImageUploadedByAirstream Forums1432470104.463576.jpg
Name:	ImageUploadedByAirstream Forums1432470123.242752.jpg
Again. Maxwell approved.
Name:	ImageUploadedByAirstream Forums1432470163.653240.jpg
Massive bed option
Old 05-24-2015, 07:26 AM   #4
1989 32' Excella
Really, all that's left is make it look good, and possibly swap the table out for something smaller for day to day living. I plan on using a dark walnut veneer on the faces or the cubbies and around the baseboard and staining in to match the floor. I'm also looking for aluminum trim for the edge of the table, and end caps of the dinette.
Old 05-24-2015, 06:40 PM   #5
2000 30' Excella
Toledo , Ohio
Nice Job
woodfox45 is offline   Reply With Quote
Old 05-24-2015, 08:10 PM   #6
2015 25' FB Flying Cloud
Eugene , Oregon
Really impressive work. You must be proud!
Meeks is offline   Reply With Quote
Old 05-24-2015, 09:54 PM   #7
Mixter's Avatar
1976 27' Overlander
Wow- you just made that so easy.... I was way over thinking that in my plan. Nice.
Mixter is offline   Reply With Quote
Old 05-24-2015, 10:11 PM   #8
1989 32' Excella
I did a lot of the same overthinking. This layout is super easy. Probably a little heavy. You could probably get away with using 12"X1" poplar and cut some weight for the base.
I'll end up redoing it at some point. Never can leave well enough alone.
Old 07-22-2015, 04:34 PM   #9
1973 31' Excella 500
Cedar Hill , Tennessee
Seating build plans
Hi, your seating looks great! Do you have any measurements, specifically the height & width of the seating? Also, what was it built from (plywood, etc)?
rob2015ellen is offline   Reply With Quote
Old 07-22-2015, 04:50 PM   #10
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Beautiful! Nice job. And in sure we all approve of Maxwell too 😃
Old 07-22-2015, 09:11 PM   #11
KYAirstream's Avatar
Northeastern , Kentucky
Does the pedestal eliminate any bounce in the table?
KYAirstream is offline   Reply With Quote
Old 07-22-2015, 09:58 PM   #12
Mission , Texas
The beautification engineer says the gaucho days in our trailer are now limited - she really liked it, great job!
nrgtrakr is offline   Reply With Quote
Old 07-23-2015, 01:38 AM   #13
1989 32' Excella
I'm out of the country for the time being, but I remember the seats being about 27" deep and 14.something" tall. The whole shebang was around 63" deep, and about 92" wide.
Old 03-20-2016, 02:04 PM   #14
1972 29' Ambassador
East Moriches , New York
Awesome Job ... I am about to undertake another restoration project and what you have done is what Im looking to do ... Can you give me an idea of measurements you used ? How tall , how wide, table size, etc ...
72TINCAN is offline   Reply With Quote
Old 10-07-2017, 02:34 PM   #15
1967 24' Tradewind
Elizabethton , Tennessee
Does anyone have plans for making something like this? We probably only have room for a queen size, but need plans. Thanks!
pythonesk is offline   Reply With Quote
Old 10-12-2017, 12:21 PM   #16
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Thanks for posting this project. Beautiful work!
We have a 92, 29' Excella Classic. Our front interior includes battery boxes like you have, plus our Converter, and Solar related Inverter, etc. A PO turned the Gaucho sideways and built an enclosed bench across the front. All of this takes up a lot of room and has absolutely zero comfort value. We've looked at several front end options, including a dinette setup. We're really struggling with deciding what would offer the most practicality and comfort. So, we're earnestly searching for a solution.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 10-12-2017, 03:11 PM   #17
65CV's Avatar
Western , Massachusetts
I posted our dinette upgrade story with drawings, starting at post 420 here. Kudos go to Zeppellium for the original concept. PDF of the plan is in post 463 -- closer in size to your queen.
Great job Chatski.
65CV is offline   Reply With Quote
Old 10-12-2017, 05:35 PM   #18
65CV's Avatar
Whoops! Here's the thread link for the post above.
Old 10-12-2017, 10:27 PM   #19
Re-Pete's Avatar
1992 29' Excella
Originally Posted by 65CV View Post
I'm getting invalid thread. I'd appreciate any help on this. Thanks
Pete
Virginia Beach, VA
Old 10-13-2017, 06:55 AM   #20
65CV's Avatar
Here's the link to the main thread, rather than trying to get fancy and land you on the right post within the thread. Obviously, you'll have to go forward to get to posts 420 and 463.
If that doesn't work, try copy/paste of this: http://www.airforums.com/forums/f109...ion-88673.html
Hope it's helpful!
John
Another gaucho to dinette conversion pageclot Upholstery, Blinds, Walls & Interior Finishes 8 04-15-2019 12:16 PM
Replaced Dinette Seat Cushion Foam in 2014 23D interstateflyer 2011 - 2015 International 3 03-01-2015 01:55 PM
Sleeping on the gaucho or dinette Jammer Airstream Lifestyle 3 01-23-2010 05:12 AM
Front gaucho or dinette? bobfowler All Argosy Trailers 27 01-03-2009 07:42 AM
Poll: Dinette VS Gaucho... robertandjenni Interior Restoration Forum 18 06-26-2003 12:40 PM
