Old 12-30-2007, 07:11 AM   #57
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Check out Friday June 8 post
My Uncle's done one of these repairs. It turned out super! Check out the June 8, 2007 post on his blog.
Chevy Ave Restorations
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 12-30-2007, 09:36 AM   #58
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I just helped a friend with this repair. It was completly down over the doorway such that you had to duck under to get into the trailer. Fortunately there were no cabinets in this section of the headliner. An uphostery shop removed the liner, cleaned the aluminum surface and installed a new headliner for $600. It looks as good as new. I consider this to be a reasonably permanent fix and it looks like original. This unit was left for years in the sun without the benefit of ventilation. Inattention does take its toll on equipment.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 12-30-2007, 01:09 PM   #59
We can tow it!
tin sista's Avatar
1996 28' Excella
Where the water tastes like wine , Michigan
Images: 82
Smile We used the screws on our 96 it worked great!
We took Georgia's (maxandgeorgia) advice and used the screws on the falling headliner in our 96 excella. Used the white screwcap covers, and we are really pleased.
It was one of the easiest jobs we've done on the trailer. Thanks Georgia!
Steph in MI Air# 6996-
I Hockeytown USA!!
tin sista is offline   Reply With Quote
Old 12-31-2007, 12:58 AM   #60
Elgin , Texas
Images: 164
I'm planning on going back with the white vinyl, but I'm going to try Reflectix in lieu of foam padding when I do it. I'll take pics when I've gotten it done.
bake315 is offline   Reply With Quote
Old 12-31-2007, 06:22 AM   #61
headliner failure ?????
Check post # 20.
Old 03-30-2008, 08:10 PM   #62
1994 30' Excella
1973 25' Tradewind
wilmington , North Carolina
Taking it off....
My 94 excella ceiling was drooping in the bedroon when I bought it a few weeks ago, the owner who inherited the camper had previously tried contact cement etc on a few spots. In the front by the door a few strips of batten were holding up some other failing areas. After reading all the threads so far I decided on taking the liner down, first in the front, tomorrow I will start in the rear and since the middle portion is still intact I will wait until it gets unbearable as it is only pulling away slightly for now. I took the first section down yesterday over the couch, about 4 x 8 give or take. I used a plastic putty knife, the majority of the liner came off without the foam. Ater I seperated the foam from the ceiling I was faced with the harder job of removing the adhesive. I tried a Shark portable steamer which really didn't do much good. Then I went to Lowes and bought a can of aerosol Goof Off. This seemed to do the truck with several applications. One can did about 1/2 of it. I went back today and bought a full gallon of it and applied it with a paint brush which after a few applications got it all off. I am saving the old liner as a template for a new piece if I decide to put another up or have a headliner shop do it which would probably make more sense. Painting might be considered but I had even thought about using Rhino Liner in a smooth finish.
Well now after looking at the reasonably shiny aluminum that is now exposed, I decided to reinstall all the curtain, vent, tv, hardware etc. And now I find I find myself really liking the way it looks even after staring at it through a few cold icehouses celebrating getting the first part of this labor done. My wife came home from work a few minutes ago and said "leave it" My son said it had a real aircraft look, all I know is that I have now some options, let me get another icehouse and evaluate it some more....am I the only sick one out there? Heck I got a 3500 sq ft house and I would rather hang out in the camper!!!
sluggo is offline   Reply With Quote
Old 04-04-2008, 07:30 PM   #63
1994 30' Excella
1973 25' Tradewind
ceiling continued....
Just finished the rear bedroom area of the falling ceiling. It was more difficult than the front for some reason or maybe i'm just tired of messing with it. It looks just like the front section witht the exposed aluminum. As for the middle section over the bathroom and the dinette mine seems to be holding up well except some lagging behind the ac unit to the point of the front where I made the first removal. I will probably just opt for a few of the screws technique as it looks like it will only take a few....for now.I guess some may ask why I didn't just do the screw thing all over but the vinyl seemed to have shrunk against where it was inserted in the plastic channels, I am more inclined to have it replaced by a trim shop and I have certainly took the labor out if the equation. So my conclusion is this.....the screw technique will certainly be the easiest, I feel though that the "poof effect", dropping down around the screws, will eventually prevail as the adhesive will continue to fail over time, when my middle section starts that it is coming down too.
Use a plastic putty knife just to keep it from scratching in case you want to leave the aluminum exposed, I like the look I just hope the vinyl with the layer of foam missing will not adversely affect the cooling of the trailer in the summer. Again, open the windows, turn on all the exhaust and the Goof Off product worked best for me. If the foam stayed on the aluminum,after pulling back the vinyl which it usually did I just painted the goof off on with a brush and gave it a few minutes to work and then it would start to come off. By myself and I work pretty steady with an occaisonal icehouse refreshment both section probably took about 8 hours each to final cleanup......the falling liner was driving me crazy but for now mine is at bay. Well now to make my appointment with Camping World to get a new frig......
Regards to all
Old 04-04-2008, 10:13 PM   #64
Elgin , Texas
Images: 164
You can also make a "knife" using a piece of wood cut on a miter. This gives you a bit more leverage, a wider blade (depending on the size of the wood piece), it isn't susceptible to melting by any of the chemicals, also will not scratch the aluminum, and, when the edge gets dull, just run it through the saw again for a new one.
Old 07-16-2009, 11:45 AM   #65
Joliet , SW of Chicago
Images: 33
Droopy ceiling repairs
Originally Posted by Inland RV Center, In View Post
Check post # 20.
Is there a special cleaner which can be used to remove the "hermetically sealed" degraded foam and residual glues from under the A/S ceiling liner?
Lucy749
Lucy749
Lucy749 is offline   Reply With Quote
Old 07-16-2009, 03:20 PM   #66
Lucy749:)
You must use a material that will dissolve the adhesive, such as lacquer thinner.
Then we follow that up with a degreaser made by Chemsearch # ND 165.
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
78 Excella 500 davidz71 Our Community 2 10-17-2002 01:11 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
airstream repair halloey General Interior Topics 3 07-27-2002 06:48 PM
Greywater drain pipe repair davidz71 Waste Systems, Tanks & Totes 4 06-04-2002 09:39 PM
