Hi gang! We have a broken counter on our bathroom sink. From what I can tell I guess the sink and the counter are one molded piece? There are 2 breaks in the countertop. I'm including a pic so you can see what I'm talking about. Should I fix them or just replace the sink/counter? If I should fix it, how would I go about doing that? Thanks!
A good boat repair yard or auto body shop that works in fiberglass can help you. There are do-it-youself kits but the time and cost of materials may be just as much as taking it to a pro. If done right - you will never see the repair and it can be made stronger.
I repaired several smaller cracks in a similar sink using fiberglass mesh tape and bondo underneath and bondo on the finish side. I put several layers of tape on in different directions then coated it with bondo for a solid structure. Sanded the bondo on the finished surface and painted with a one-part epoxy.
