Old 08-26-2003, 08:19 AM   #1
Cecil Stone's Avatar
Repair 84 Sovereign Front Interior Panel
I have a 1984 Sovereign that the front molded panel has began to crack. It has about a 8" crack now. Any ideas as to how to repair, etc. thanks.
Cecil Stone
Cecil Stone is offline   Reply With Quote
Old 08-26-2003, 07:59 PM   #2
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Drill it....
My 84 Excella has a crack in the front panel. The previous owner drilled a VERY SMALL TINY hole at the end of the crack to stop the crack from running, and it has not ever run any more. Other than that it is not very noticeable, and I have done nothing else to mess with it.
dscluchfc is offline   Reply With Quote
Old 08-27-2003, 06:48 AM   #3
There is a long thread on this issue at http://www.airforums.com/forum...3985#post33985
Mark
Old 08-27-2003, 10:16 AM   #4
Thanks for the info on repairing the crack in my 84 Sovereign. Still not sure the best route to take.
Old 08-27-2003, 05:31 PM   #5
dinoburb's Avatar
1982 34' Limited
Tidewater , Virginia
Without seeing the type and size of the crack one can only guess . . . However, as a retired Navy pilot and Aircraft Maintenance Officer the advice given by dscluchfc is sound. Generally a small hole drilled at the very end of the crack will stop the progression of the crack. It's known as stop-drilling and it is a very effective method of halting the crack.
Actual repair of the crack is another question, better dealt with when the type and extent of the crack is better known.
Take care,
Sean
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline   Reply With Quote
front MH grill repair Astrodokk Airstream Motorhome Forums 10 03-27-2004 04:09 PM
jack nife - front skin repair - parts ? JimWeed Ribs, Skins & Rivets 3 12-31-2003 12:01 PM
front suspension/ ball joints wb13798 Mechanics Corner - Engines, Transmission & More... 13 11-07-2003 07:57 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
