While you are that 'deep' into the project.. you might consider doing what we did in a small area.
I purchased some special 'epoxy' called 'GitRot'. It is a thin epoxy which repaired a 'softening area' on our 1999. I will utilize this process whenever I discover a 'floor' issue like this in the future. It would add a bit more cost, but potentially a lot longer LIFE in your AS..
There is another site I recently discovered (by help of a friend here) that specializes in epoxy and where you might consider as a 'source' for your project. PM if interested in knowing more.
Basically, you could drill 1/8" holes partially into the floor along the perimeter, inject the almost "water" consistency epoxy into the wood flooring and this will 'tighten up' and waterproof the area... we have had 3 years on the 'fix' and no issues..! We have had occasion where water penetrated in the same area but, was just a damp spot on top of the epoxy..!!!
We were able to resolve the leaks without worrying about potential 'damage' in the area..
Good job on your Airstream!
Peace and Blessings..
Channing
WBCCI# 30676
