Old 12-22-2014, 06:47 PM   #1
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
Removing Zolatone from interior back end cap
I have the interior skins out of my '61 Safari. The front end cap is fiberglass. The Zolatone on it washed up nice and looks decent. The back end cap is aluminum panels and the Zolatone on it was far more corrupted. When I power washed it, much of it blasted off exposing the clean shiny aluminum underneath. I plan to have our "Master" bedroom in the back and would like to get the whole end cap to a mirror shine. (yeah baby, mirrors on the ceiling! )
Can anyone point me to a how-to for getting all the Zolatone paint off? I'm assuming I want to do it before I reinstall the skins.
Thanks!
-503
'61 Safari
http://airwave503.blogspot.com/
Airwave503 is offline   Reply With Quote
Old 12-24-2014, 06:43 AM   #2
Harperbear's Avatar
Arden , North Carolina
I used paint stripped that comes in a gold can from Home Depot. I forget the name but it starts with a J. Nasty stuff but it gets it off. The real question is how to seal the polished look so it doesn't corrode when it is touched or just over time. Let me know if anyone has an answer.
Harperbear is offline   Reply With Quote
Old 12-26-2014, 10:51 PM   #3
1966 30' Sovereign
Albuquerque , New Mexico
Jasco Epoxy and Paint remover. Wear a respirator and chemical gloves. Stuff burns on contact with skin, but washes off with water.
I've heard Rustoleum clear coat works well in areas where the sun won't eat it up.
bwchant is offline   Reply With Quote
Old 12-27-2014, 09:01 PM   #4
esmaytum's Avatar
1963 28' Ambassador
1978 28' Ambassador
Boerne , Texas
end cap paint removal
I used the paint stripper in the gold can from home depot and airplane stripper both work but are extreme. They will eat the gloves off you hands and since you will be applying it above your head look out for drips to your face. After being burned alive on the front cone switched to Citrustrip. It does take longer to lift but it will work. I painted it on thick waited 3 hours then scrapped off the other 5 layers of latex with a Bondo knife then put it on again and washed it off with water and 0000 steel wool. Then polished it with Nuvite. I have a 56 Flying Cloud so both cones are aluminum 13 panel.lots of rivets to clean but worth the time. Now I'm sure there will be 50 conterdicion to my way but it's just that "my way"
esmaytum is offline   Reply With Quote
Old 01-06-2015, 10:46 AM   #5
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
Thanks, the end cap is out so I can do it on the ground. I will try the nasty stuff first.
'61 Safari
Old 02-02-2015, 04:47 PM   #6
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
OK, I am into this now with the Jasco and it's proving to be much slower and more difficult than I was hoping...(wait, that pretty much describes this whole project! )
Please share any tips you have or point out things I might be missing.
The directions to paint in on, I find I need to slather/glob it on to get any results and I have to apply it where gravity will let it pool, vs. run and dry.
I wait ~15 minutes, some spots will be "lifted" and some seem barely affected. Did you guys find it was better to let it sit for more or less time?
I shook it up pretty good but it's still fairly jelly-like with some lumps that don't break down. Is this normal? I am almost through a quart and I think I'll need a gallon to finish the one end cap...sound right?
Even in the best cases a gluey residue is left behind. I tested using some scotch-brite with mineral spirits and it cleaned it pretty good but clouded up the finish...I think and hope it will polish back to a shine but I don't want to cloud up the whole thing or I will be polishing forever.
Again, this is Zolatone..the ballistic oatmeal colored paint they used in the early 60's before they went to vinyl.
Estmayum, I assumed you used a plastic bondo knife for scraping, but did the steel wool not thrash your finish? How hard was it to polish back to mirror?
Name:	Paint stripping.jpg
'61 Safari
Old 02-02-2015, 10:23 PM   #7
1966 30' Sovereign
I found the Jasco worked best when warmed up with the skin warm as well. One day it was only about 50 degrees in the trailer and the stuff didn't do anything. I placed a heater in front of the un opened can to warm the contents and waited until the can "poofed". I spread it on heavily and waited about 20 min then repeated with another layer waiting another 15min. Used plastic scraper. I read somewhere else not to use steel wool as scratches are hard to remove. I stripped my entire insides using 4 gallons of product.
Old 02-02-2015, 10:33 PM   #8
reinergirl's Avatar
Hollis , New Hampshire
I used Citrastrip and plastic razor blades. My experiences are on post 66 here
http://www.airforums.com/forums/f109...ml#post1173110
reinergirl is offline   Reply With Quote
Old 02-03-2015, 08:15 AM   #9
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
Loving this forum!
bwchant - Yes! The temperature crossed my mind...I forget what it says on the can for the ideal temperature range but I remember thinking it's colder than the range here right now. I will figure out a way to heat things up!
Shelly - Great tip on the plastic razor blades! I think you have also convinced my to take apart my end cap. This way I can lay the pieces flat to work on them and I won't have to clean the rivets (which dulls up the blades). I'll replace them with nice shiny new ones.
Alright, I gotta plan!
'61 Safari
Old 02-03-2015, 09:16 AM   #10
toastie's Avatar
1955 22' Safari
Great Lake State , .
Like this........toastie
toastie is offline   Reply With Quote
Old 02-03-2015, 10:07 AM   #11
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
Stylin Toastie! (I wish my front end cap wasn't fiberglass )
'61 Safari
Old 02-03-2015, 08:25 PM   #12
esmaytum's Avatar
1963 28' Ambassador
1978 28' Ambassador
Boerne , Texas
I use the metal bond blade with the handle on top. It bends with the curves and kinda of slices the zolatone like cheese . I didn't have any problems and the 0000 steel wool scratches less that the green scrub pads (I think)Click image for larger version
Name:	ImageUploadedByAirstream Forums1423020317.196260.jpg
Old 02-03-2015, 08:45 PM   #13
reinergirl's Avatar
Colin Hyde sells kits to do your own aluminum endcaps. I believe precut and packaged at $440, which I think is rather reasonable.
https://sites.google.com/a/colinhyde...ions.com/home/
He's also Colin H here on the forums.
Old 02-06-2015, 12:17 PM   #14
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
OK, progress! Found some plastic razor blades and a good scraper at my local Autozone. Took the end cap apart and removed all the old rivets and smoothed out all the holes so there was less to dull up my plastic blades. Ran a space heater in my garage to warm up both the panels and the gallon can of Jasco. So happy when I started scraping at the Zolatone came up like cheese! I also seemed to notice that if I left the can of Jasco open, there we're less gelatinous clumps and it poured on more liquidy which made it easier to spread. Still a lot of residue underneath...going to try that 0000 Steel Wool and see if it doesn't scratch too bad.
'61 Safari
Original Zolatone or New Zolatone - Value judgement? robwok General Interior Topics 1 12-05-2014 09:34 AM
Removing dents from Argosy steel end cap VtTim Ribs, Skins & Rivets 7 01-28-2014 08:15 PM
removing an end cap ClayC General Interior Topics 1 04-03-2010 02:57 PM
Removing Zolatone texture & repainting interior - primers, etching, topcoats Jacob D. Upholstery, Blinds, Walls & Interior Finishes 9 04-02-2007 10:54 PM
Interior End Cap mjohnson63 General Interior Topics 4 04-07-2004 05:34 PM
