Old 01-28-2007, 07:44 AM   #1
1973 23' Safari
Maryville , Tennessee
Images: 13
Removing Trim in Bathroom
Are there any secrets or easy ways to remove the trim around the bathroom cabinets and shower? They have all yellowed and I am doing the epoxy treatment on the area soon and want to remove the trim. Thanks in Advance...
Kevin
kneal is offline   Reply With Quote
Old 01-28-2007, 08:10 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
The aluminum strip had to be riveted in place and then the plastic middle "insert nosing" slid in from a free end. Maybe a cabinet was later installed to block that end or can you see a way to slide out the insert nosing? It is available ... Inland or Oasis. (Airstream Parts Sale Inland RV Center, Inc. (951) 734-8130 -- part #71411) It will be brittle and you can feel okay about destroying it. There'll be rivets behind to remove, then the aluminum trim strip comes off. You'll still need to create a way to slide the insert nosing in after you re-rivet the strip.
5 meter Langford Nahanni
Old 01-28-2007, 08:13 AM   #3
The backside of new insert nosing may have to be lightly sanded to make it thin enough to go into your aluminum trim. Some oil-free silicone (LPS-1) will help slide it in but you may still need to thin the insert nosing slightly.
Old 01-28-2007, 08:36 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Insert nosing
I was told by Inland RV last week the "insert nosing" is the U or V shaped flexible plastic that goes over the edge of the counter where it fits into the U groove at the top of the aluminum piece which supports the counter edge. This sounds like a different part than what was described above. There is a illustration of the part on the Inland website.
Old 01-28-2007, 08:49 AM   #5
The way I interpret Kevin's post is that he wants to remove the trim strip circled in red:
I've used Inland's insert nosing and it is the part in the middle so labeled. Insert nosing is flat. I've got a digital pic of my coil on the computer somewhere -- cuz I sold the remainder to another forums member.
Kevin -- help us out here.
Old 01-28-2007, 09:51 AM   #6
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
My insert nosing was yellowed and cracking. I just grabbed one end with a pair of pliers where it was cracked and started pulling. New nosing was inserted in the edge of the bottom track, slightly bent and then inserted into the top track. You just keep feeding it in bottom then top as you go. Do not insert and expect to push it through the end of the track toward the other end.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-28-2007, 10:05 AM   #7
sequoiacoast's Avatar
1968 24' Tradewind
Eureka , California
I have a '68, so mine may be different... but I just pulled the top piece off. It was stuck on by pressure, but with needle-nose pliers, it just came off. The piece underneath was riveted on. I saved each piece, thinking I'd re-use it, but ended up stepping on one piece.. so...
I looked everywhere for a replacement, even Inland RV, and nothing was what I had before- besides, after repainting, the colors wouldn't have matched up. So, I used aluminum trim found in the flooring section of the local hardware store. It's pre-drilled, so I just cut and riveted. Easy!!
ID:	31436   Click image for larger version
sequoiacoast is offline   Reply With Quote
Old 01-28-2007, 10:06 AM   #8
1976 25' Caravanner
Campton , New Hampshire
This is also how I inserted the blue stipping on the outside moulding .
ticki2 is offline   Reply With Quote
Old 01-28-2007, 10:10 AM   #9
Lumatic's Avatar
1993 34' Excella
Images: 16
Will the real insert nosing please stand up
I have 3 types of what could be described as "trim" on my bathroom sink. Hopefully, my photos will come through. If anyone can give me a better idea of what they are called and where to get them it will be appreciated:
1. rubbery flexible trim that folds over the bottom flange of the sink counter and inserts in aluminum channel.
2 and 3 insert nosing? covers top flange of sink where it is is riveted to the trailer wall. This is what looks most like what is called "insert nosing" on the Inland RV wbsite part#71411. It has a lip on each side and so is not completely flat.
4. formica like flat trim that covers the aluminum facing on the front of the sink cabinet just under the counter. This is flat and attached with double sided foam tape
ID:	31438   Click image for larger version
ID:	31440   Click image for larger version
Old 01-28-2007, 10:13 AM   #10
Right -- not completely flat. I'd say that the closeup picture with the black background looks like Inland's part 71411 to me. And Kevin -- they don't come with a hole in it like Marshall's pic.
Old 01-28-2007, 10:22 AM   #11
davidz71's Avatar
1986 25' Sovereign
When I called Inland RV and described this insert in my rear bath '77 they immediately knew it was insert nosing and sent the amount I requested. I ended up with just 4" extra so I got just the right amount.
Craig
AIR #0078
3.73 rear end
Old 01-28-2007, 02:23 PM   #12
1973 23' Safari
Images: 13
I am looking to take both the insert and the aluminum trim off. I guess from what I am reading I will need to remove the insert and then drill out the rivets? Am I reading this right?
Kevin
Old 01-28-2007, 02:48 PM   #13
Right.
Old 01-28-2007, 04:10 PM   #14
Lumatic's Avatar
1993 34' Excella
Images: 16
We may be comparing apples and oranges, bit on my Trade Wind the "aluminum trim" is an integral part of the sink/counter support structure.
See my photo above.
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 08:01 AM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
Removing wallpaper from 76 tradewind Rennegarbe1 Upholstery, Blinds, Walls & Interior Finishes 4 02-05-2003 04:52 AM
Bathroom Counter Trim 74Sovereign Upholstery, Blinds, Walls & Interior Finishes 1 07-10-2002 06:36 AM
Exterior trim ALANSD Airstream Motorhome Forums 1 04-14-2002 07:53 PM
