Old 01-28-2007, 05:21 PM   #15
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by kneal
I am looking to take both the insert and the aluminum trim off. I guess from what I am reading I will need to remove the insert and then drill out the rivets? Am I reading this right?
Kevin
Sorry, I had to go back and re-read your post. The aluminum trim is riveted to the counter and yes, you will have to drill the rivets out to remove the trim. Stupid question but are you doing the epoxy treatment to resurface your counter? My '77 had some kind of panel surface which was buckling up and had to be glued back down.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-28-2007, 05:35 PM   #16
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Kevin,
Just follow Craig's advice: grab it with pliers and pull it out. You won't save it, it will break apart and isn't worth reusing anyway.
Rather than replacing it with more of the same (kinda pricey), I just cut strips of linoleum and slid them in. The trim now matches the floor and looks nice.
As to your question regarding rivets, yes the trim hides the rivets on the aluminum trim. Once you remove the aluminum trim, you'll find there are still some more rivets behind that. Be careful drilling those out as they tend to spin.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 01-28-2007, 05:41 PM   #17
1973 23' Safari
Maryville , Tennessee
Images: 13
Great. Thanks for your input. I removed the insert today and did a few other things to prep for the epoxy process. Thanks again for your help!
kneal is offline   Reply With Quote
Old 01-28-2007, 05:49 PM   #18
1989 29' Excella
afton , Virginia
We just removed brittle nosing in our 74 Argosy....used a piece of wide, vinyl vertical blinds (leftovers) trimmed them to size....very pliable, easy to trim and cut to size, easy to insert.
alumibum is offline   Reply With Quote
Old 01-28-2007, 05:56 PM   #19
PizzaChop's Avatar
1973 31' Sovereign
Images: 202
2-part epoxy paint
Kevin,
Just remember that it takes two coats with the epoxy. The first coat won't look great and I tended to over apply (which creates runs). Follow instructions to the letter and you'll be very pleased with the results.
Ron Kaes
Psalm 112
www.paparonnis.com
Old 01-28-2007, 07:48 PM   #20
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Hey Ron,
I'm just about ready to paint using the epoxy. Do you have any recomendations re:
1. final sanding- how fine?
2. surface prep- the instructions say use (a)muriatic acid x3 or (b) TSP scrubbed with "Rhoades American" 000 steel wool x3
Do you think the brand of steel wool matters?
Old 01-28-2007, 07:59 PM   #21
CanoeStream's Avatar
St. Cloud , Minnesota
I am aware that there is an oil free steel wool. Rhoades American? I'd have to check. I have a resource book from the folks at Fine Woodworking. I can get brass wool locally but don't know its specs as far as oil content.
5 meter Langford Nahanni
Old 01-28-2007, 08:07 PM   #22
Lumatic's Avatar
1993 34' Excella
Images: 16
I'm not sure why the Tough as Tile instructions call for this specific brand name. It doesn't give a reason. It didn't even occur to me about oil.
Old 01-28-2007, 08:18 PM   #23
Okay, a Taunton (Fine Woodworking) reference I have for oil-free steel wool leads me on a path right to "Rhodes American" steel wool. Rhodes is the correct spelling. Google on Rhodes American and you will see several sources. Otherwise it is the bottom four choices at Item Display Page
I'd think of using wet-or-dry cloth aluminum oxide in only the finest grits. Avoid garnet. Ace Hardware is better equipped than most other chains -- not sure I'd make a trip to Home Depot unless they were very close.
Be very careful about steel wool around aluminum. Work to keep the dust away from going down cracks & crevices. The bimetallic reaction with aluminum will contribute to corrosion.
Old 01-29-2007, 05:55 AM   #24
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
It is very safe to use bronze wool with aluminum, then clean the surface with thinner etc.
'77 Sovereign Intl 31' CB
Old 01-29-2007, 09:17 PM   #25
Lumatic's Avatar
1993 34' Excella
Images: 16
Tough as Tile preparation/ Steelwool
Got this reply from Tough as Tile:
Rhodes American steel wool is not oil free. Oil has to be used as part of the manufacturing process of steel wool. You can use any kind of steel wool as long as it is 000 or 0000. Tough As Tile can be used on a lot of surfaces. However, unless the plastic surface is a very hard plastic our product will not hold up very well and may peel because there is too much give in a lot of plastic surfaces.
Old 05-29-2007, 06:36 PM   #26
pattyo's Avatar
1985 25' Sovereign
South Berwick , Maine
Images: 11
Insert Molding? 1977 Argosy Minuet
Has anyone tried replacing this trim with 1 inch RV insert molding? Thought I'd check before buying it.
WBCCI # 4933 New England Unit
Tin Can Tourists Vintage Club
pattyo is offline   Reply With Quote
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 08:01 AM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
Removing wallpaper from 76 tradewind Rennegarbe1 Upholstery, Blinds, Walls & Interior Finishes 4 02-05-2003 04:52 AM
Bathroom Counter Trim 74Sovereign Upholstery, Blinds, Walls & Interior Finishes 1 07-10-2002 06:36 AM
Exterior trim ALANSD Airstream Motorhome Forums 1 04-14-2002 07:53 PM
