Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 02-24-2007, 06:09 PM   #1
Profile:  1967 26' Overlander
ventura , California
removing the interior skin
so i have a 67 overlander with alum wiring and i need to remove the int skin my question is once i remove the skin can i drive the trailer from the place i work on it to my storage place which is about 15 miles each way thanks for everyone help.
brandok is offline   Reply With Quote
Old 02-24-2007, 06:18 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Take it easy and I think you'd be okay. There will be less rigidity with the inner skin removed, so drive gently. The bigger consequences would come if somebody, 1.) wanted this to be their long term design, and 2.) insisted on driving at highway speeds.
BobStream
...You really don't know someone 'til you've had recess with them. ...Alex Ziton, age 8
Old 02-24-2007, 06:44 PM   #3
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
Bob is right, there would be less rigidity, but in the end, if you didn't tow it like you stole it, you should be fine.
Old 02-25-2007, 01:09 PM   #4
cool thanks very much i am going to take the back roads the whole way never getting over about 40 miles and hour. i have further instepcted the frame and it looks as if i am going to have to remove the body from the frame anyone have any have any ponters and any idea how many peps it would take to lift it off thanks for all your help
removing Dometic Refrigerator smily Refrigerators 14 10-29-2007 04:01 PM
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 11:21 AM
Removing wallpaper from 76 tradewind Rennegarbe1 Upholstery, Blinds, Walls & Interior Finishes 4 02-05-2003 04:52 AM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 06:51 PM
Removing Vulkem JrnymnJay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-03-2002 11:49 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
