Old 07-12-2009, 01:32 AM   #15
1979 30' Argosy
saint augustine , Florida
silverslug...i like where you are going with your idea of removing only the offending "dashboard" and leaving the restof the dome intact. i'll be doing to the same to my front end soon. please let me know what you have done. i'm thinking after the "hide-away" cubbys are gone i can mkae the whole front one smooth piece. i'm covering my interior with wood veneer.
greenRNtrav. is offline   Reply With Quote
Old 07-12-2009, 06:30 AM   #16
1994 30' Excella
Mississauga , Ontario
Double check on the end cap. I'm not sure but think that I have read on the forum that the end caps are actually made of ABS plastic, not fiberglass.
Al
Old 07-12-2009, 08:10 AM   #17
StingrayL82's Avatar
San Angelo , Texas
Images: 37
The front cap is plastic; the rear bathroom cap is fiberglass...at least on mine.
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 07-12-2009, 10:42 PM   #18
Silverslug75's Avatar
1973 31' Sovereign
Vashon , Washington
Okay, I just cut out the non-dome shaped dashboard part of the endcap with a common handheld jigsaw and fine blade and it worked beautifully. I next will get some cardboard to make patterns for wooden ribs which will form a skeleton upon which to complete the dome shape for the end caps using the 1/8 inch doorskin plywood. I will take some pictures of the process for anyone who may be interested. I will save my patterns if this works, in case others want to try this.
Silverslug75 is offline   Reply With Quote
Old 07-12-2009, 10:50 PM   #19
1973 31' Sovereign
Vashon , Washington
Here is an example of what another forum member did, sorry but I lost the link of where I found this. This is so beautiful!
Old 07-13-2009, 07:34 PM   #20
Streamer Jabe
Jabreyd13's Avatar
1978 31' Excella 500
Edmond , Oklahoma
that's picture is so small I can't see it.
Jabreyd13 is offline   Reply With Quote
Old 07-13-2009, 07:54 PM   #21
Kevin245's Avatar
Here's the link. We posted a thread about using wood veneers and panels over interior skins, and this was from one of the posts.
Best of Luck,
Kevin
silver-suenos - Home
Eleanor Roosevelt
Old 07-15-2009, 07:43 AM   #22
1973 31' Sovereign
Vashon , Washington
Thanks Kevin. Your pictures are gorgeous and a real inspiration for our project.
Old 07-15-2009, 10:52 AM   #23
Kevin245's Avatar
I wish they were of our AS, but they belong to another forum member who posted on a recent thread I started. We're starting our full monte restoration soon and are interested in using birch plys on some of the interior walls. We looked at a friend's 75th anniversary AS a few weeks ago, and my SO likes the mouse fur walls, so we'll likely incorporate some material coverings as well.
I plan to ditch the plastic end caps on ours too. Ours are cracked, and IMHO they are butt ugly.
Keep pushing ahead with your project and keep the photographs coming.
Regards,
Kevin
Eleanor Roosevelt
Old 07-15-2009, 07:28 PM   #24
1973 31' Sovereign
Vashon , Washington
At This Point...
Here's what it looks like now. Next steps are to figure out exactly what we will be doing with the wiring before sealing it back up.
Name:	airstream rm2 009.jpg
ID:	83971   Click image for larger version
Name:	airstream rm2 006.jpg
Name:	airstream rm2 007.jpg
Old 07-15-2009, 07:36 PM   #25
Ottawa , ON
I think the leads for the speakers run through there, and they are often forgotten, so figure out where you will put the sound system and move the wires accordingly.
And of course, some of that wiring is for lights, I'll bet (plus maybe the fan in the vent you have the screen hanging out of), so it goes without saying that you make sure everything works before sealing it up again.
Old 07-15-2009, 08:17 PM   #26
CrzyCorpsman's Avatar
1975 31' Sovereign
Biloxi , Mississippi
SilverSlug,
Sorry my pics never came out, but the other members pics are the same as mine. You can visit my blog below for the pics that I was trying to show you. Just visit the Dec 2008 posts.
Keep us posted on your progress. I had wanted to do the very thing that you are doing with the wood paneling instead of the ugly end cap. I was talked out of it, but still want to do it
Good luck. I look forward to following your progress.
Brian Schmock
'75 31ft Airstream Sovereign
Come check out my restoration progress:
http://crazycorpsman-silverbullet.blogspot.com/
CrzyCorpsman is offline   Reply With Quote
Old 07-28-2009, 06:48 PM   #27
SWEET THING's Avatar
1970 31' Sovereign
HUNSTVILLE , Texas
Hi Minno,
Just curious as to how you completed your end cap. I am restoring my 1970 31' and am looking for ideas. I'm thinking of a new cabinet for storage and a place for the control panel (like before) also a place for my new stereo. Any ideas or thoughts would be greatly appreciated!
Charlotte
SWEET THING is offline   Reply With Quote
Old 07-29-2009, 08:08 AM   #28
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Hi Charlotte,
I'm still a couple of years from having to worry about building a new front end cap. My thougts are to use the rear end cap as a mold, and build a new front end cap out of fiberglass fabric and epoxy, using a release agent on the rear end cap so the new front cap won't stick to it. I've used fiberglass fabric and expoxy resin to repair a Wenonah canoe, so I'm fairly comfortable that I can do a new end cap ok. We'll cover the inside surface of the end cap with our wall/ceiling covering that we'll use - whatever that ends up being.
Chris
Removing interior front endcap Mister Ed Ribs, Skins & Rivets 4 01-15-2009 09:17 PM
Removing Kitchen counter assembly quality parts Cabinets, Counter Tops & Furnishings 4 12-11-2004 05:47 AM
removing inner window on curved front windows remcolent Windows & Screens 1 04-12-2004 03:55 PM
Front Travel lounge Assembly gvanman General Interior Topics 4 07-17-2003 09:58 AM
