Old 02-17-2013, 10:43 AM   #15
reinergirl's Avatar
Hollis , New Hampshire
Originally Posted by rowdyATX View Post
Is there any reason to strip and clean the interior panels before I remove them?
Not really IMO they are easier to clean and strip when they are flat.
reinergirl is offline   Reply With Quote
Old 02-18-2013, 10:51 PM   #16
rowdyATX's Avatar
1956 26' Cruiser/Overlander
1961 28' Ambassador
After working for several hours stripping paint off the door, I am going to take your advice and plan on going with new aluminum for the interior skins.
Where is a good place to pick up sheets of aluminum? How much per sheet am I looking at?
rowdyATX is offline   Reply With Quote
Old 02-18-2013, 10:55 PM   #17
rowdyATX's Avatar
1961 28' Ambassador
Originally Posted by 68 TWind View Post
If you don't have the special sheet metal drill bits regular 1/8 in will do. Use a fresh sharp one and when one gets dull toss it. Drill the head off and if the shank is till in the hole use an 1/8 punch to push it out ( back into the wall cavity) Also, keep a pair of vise grips handy. The rivet heads will stack up on the shaft of the drill bit as you drill them out. When that happens grab the bottom few with the vise grips and run the drill in reverse , the heads will "walk" off the end.
Label the panels and reuse them if you can. Buy some Cleco fasteners from any Aircraft supply house or Vintage Trailer supply and a cleco tool to insert and remove them. They are worth their weight in gold when you are installing panels.
Thanks for the "vice grip" advice. My wife raised her eyebrow at me and asked, "how did you know to do that?" I just casually replied, "that's just how I am." It got me a lot of points
Old 02-18-2013, 11:13 PM   #18
rowdyATX's Avatar
1961 28' Ambassador
Also, should I use the same aluminum for the belly underneath and the interior? Is there a chart to refer to?
Old 02-24-2013, 10:03 AM   #19
rowdyATX's Avatar
1961 28' Ambassador
Can you tell which cleco tool I need, exactly?
I found these but not sure what to buy.
http://www.yardstore.com/browse.cfm/2,425.html
Old 02-24-2013, 12:45 PM   #20
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
clecos
They come in color coded sizes...like the rivet sizes. figure out the rivets you want to use and get some clecos to fit. Use EBAY and you can save a bunch. Ft Worth and San Antonio have good aviation communities and you will find lots of good deals there.
