Old 07-14-2006, 12:28 PM   #1
1990 34' Excella
Windcrest , Texas
Removing Interior Skins
Hello everyone, the student has returned
I'm preparing to install a surround sound system in our Excella and was curious about how I should install the wiring. One thought I had was to pull some of the interior rivets and run the wiring behind the skins.
So...does this make sense to you? I'm not sure if I need to completely remove the interior skin to prevent it from bending or can I simply remove the rivets along one edge, run my wires and then replace the rivets.
Any input you can provide would be great!!
Mitch
Swanny is offline   Reply With Quote
Old 07-14-2006, 12:38 PM   #2
The wiring must be threaded through the main bows and/or horizontal stringers, as the case may be.
Old 07-14-2006, 02:56 PM   #3
New Borockton , Alabama
Images: 21
Mitch,
I am considering surround too and thought a wireless system would be the way to go. I haven't done much research but wondered if you had even considered wireless.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 07-19-2006, 04:20 PM   #4
1990 34' Excella
Windcrest , Texas
Would you recommend completely removing the skins?
I guess this means I should completely remove the affect skins. Are you guys aware of a thread on this forum that describes how to do this?
Is there a special rivet puller that should be used, etc? Thanks
Mitch
Old 07-19-2006, 05:41 PM   #5
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
you'll see almost the same thread title here
http://www.airforums.com/forum...der-21356.html
here's a shorter answer to your question
http://www.airforums.com/forum...kin-21111.html
if you want to do a top job, you'll have to take the ceiling skin down. It's actually not too bad a job, you can do it alone--the trick is to get the skin from concave to convex along it's entire length, then you can pull one side from the rail. You'll find all the wires up there, then they branch off and go straight down the wall.
Taking down the larger side skin is more difficult--lots more rivets and they are difficult to open partially because they have such a concave shape. You can get a little opening at the ends, but you'll find that it's easier to take out all the rivets along one edge (top or bottom) and curl it a little so you can get your hand inside. I recommend the bottom edge, since you'll be able to thread wire behind it from the top.
Old 07-20-2006, 11:39 AM   #6
1990 34' Excella
Windcrest , Texas
Thanks Zep
Zep....
Thanks a bunch for the great direction. Now I have my weekend planned
Mitch
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 04:36 AM
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 12:21 PM
Removing wallpaper from 76 tradewind Rennegarbe1 Upholstery, Blinds, Walls & Interior Finishes 4 02-05-2003 05:52 AM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 07:51 PM
Removing Vulkem JrnymnJay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-04-2002 12:49 AM
