Old 12-26-2014, 09:41 AM   #1
1975 25' Tradewind
Navarre , Florida
Removing Center Overhead Beam
Anybody have a good way to remove the cross beam that the accordion door attaches too. I'm hoping i dont have to remove any overhead cabinets but if that's what it takes.... The only screw I can see that is drilled through the beam is tucked in behind the control panel.
I'm 6' 1" and the beam is 6' so it's got to go.
Rsmied is offline   Reply With Quote
Old 12-26-2014, 10:59 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
As I remember the screws are up in the slide itself.
Old 12-27-2014, 05:40 AM   #3
1975 25' Tradewind
Navarre , Florida
no screws up in the slide. it appears it is just resting on top of the divider wall and wedge in between the two overhead lockers. Guess i'll have to remove one or two of the lockers to take the beam down.
Old 12-27-2014, 07:19 AM   #4
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
I was going to take mine out at one point to reverse the door and as far as I could tell you are correct on how to get it out. It was more work than it was worth so I left it alone.
Flynavy is offline   Reply With Quote
Old 01-02-2015, 02:13 PM   #5
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I took mine out with a Sawzall. Obviously, it ain't goin' back in.
Old 01-02-2015, 02:50 PM   #6
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I was going to say, I hate to destroy anything on a vintage trailer, but before I'd be taking out cabinets, I'd try sawing out that bad boy.
Stephanie
Old 01-26-2015, 08:10 PM   #7
1975 25' Tradewind
Navarre , Florida
sawzall was the way to go. 1 cut down the center was all it took and now I dont have to worry about hitting my head every time I walk through the trailer
axles: beam or torsion? apmason Axles 12 08-01-2012 02:03 PM
1.5" I beam or aluminum square tubing for installations??? robwok Furnaces, Heaters, Fireplaces & Air Conditioning 15 11-03-2011 08:30 AM
Beam me up Wally mandolindave Off Topic Forum 0 10-02-2007 06:02 AM
Combination switch for high beam spat61 Classic Motorhomes 2 09-24-2007 05:35 PM
GE patio light H12 sealed beam philippes Electrical - Systems, Generators, Batteries & Solar 3 03-17-2007 08:20 PM
