Old 08-03-2005, 11:35 PM   #1
Removal of wheel and cover
One of our trailer's wheels and its cover is inside the vanity (under the bathroom sink). Since the trailer will never be moved again, and since we want to redo the bathroom, we need to remove that wheel and its cover.
We're not sure where to start on this. Any do's and don'ts? Anyone has done this before?
TIA !
Agnes
Agnes is offline   Reply With Quote
Old 08-04-2005, 01:09 AM   #2
1992 34' Limited
Falls Church , Virginia
Photos????
Agnes -
Photos ALWAYS help those who try, or what to assist!!!! Any and all photos of current situation helps. Also, any description of where/why/ what you want to do are helpful in figuring out if your way is the best, or it there are perhaps other ways of achieving the desired goal and not hurting your long term value. Just a thought....! Trailer is being parked LONG term?? AS's are meant to MOVE baby!!!!! My 2 cents...
Goood luck in whatever direction life takes you!
Axel
SilverToy is offline   Reply With Quote
Old 08-04-2005, 10:25 AM   #3
Yes, this trailer has been where it is for 11 years and is permanently attached to an addition. No moving this baby, no way !
I will try to get a picture, it's difficult as it's hidden in the vanity and I can't back up enough.
Thanks for your prompt reply!
Agnes
Old 08-04-2005, 09:21 PM   #4
Ok, I got a couple of pics, now how do I post them?
Old 08-04-2005, 09:25 PM   #5
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Click on reply and scroll down to bottom of text box.
Click "go advanced" add text to message window and then scroll down.
Click "Manage attachments" A separate window will pop up.
Click "browse" Then select the file to be uploaded. Be sure that the photo is appropriately sized. 400 x 600 pixels (or smaller) and no more than 100 kilo bytes. You may select several photos to upload at the same time by repeating the last step.
Click "Upload" After pics have loaded close the pop-up window
Click "submit reply" to mount the text of your message - photos will automatically appear in post.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 08-04-2005, 09:34 PM   #6
Thank you Janet! Your instructions were very clear !
Ok, the first image is the one that needs to go. It's under the little vanity. Since it's hard to see, I took a picture of the other wheel cover, this one is in a larger closet so it's more visible.
Thank you all for any advice
Agnes
ID:	13802   Click image for larger version
Old 08-04-2005, 09:56 PM   #7
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Now I get it! You want to remove the wheel and the wheel well.
Just like you said....
Well, that would more or less transform this from a trailer into a cabin or shed.
Take the wheel of from the outside, and then start removing the screws from the inner wheell well, all the way around. It might be riveted to the inner skin, so you will have to drill out the rivets.
Then, you will have to drill out all the rivets that hold the outer wheel well to the outer skin, and remove it. This will be difficult, because the wheel well tucks under the flooring. But since you will have to extend the flooring anyways.....no - sorry, can't help you further. You're looking at a highly unusual modification to an Airstream.
Uwe
www.area63productions.com
Old 08-04-2005, 10:04 PM   #8
You want to remove the wheel and the wheel well. Just like you said....
Well, I didn't know that a "bump" would be called a well
Yes, we call it the cabin too .
Does this fall into an average person's ability, or should we look for someone with a handy streak?
Stainless stove cover repair somefun Stoves, Ovens & Microwaves 21 01-09-2006 05:53 PM
Exterior electrical outlet cover airstream4 Exterior Restoration Forum 1 12-05-2004 01:37 PM
