Old 06-03-2016, 05:27 PM   #1
2013 19' International
Stockton , California
Red Light near Refrierator
We have a 2013 Bambi International. There is a red light switch on the wall to the left of the front door that has something to do with the refrigerator. When it's on, the fan runs even if the fridge is turned off. Does it need to stay on all the time? What does it do specifically if the fridge is off? Thanks.
Buck1948 is offline   Reply With Quote
Old 06-03-2016, 06:28 PM   #2
. , At Large
The switch is for the fridge fan, and helps the fridge get colder than without it.
Old 06-03-2016, 06:37 PM   #3
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
It does not need to stay on all the time. If your refrigerator is off, there is no need to keep the fan on.
The switch is for times when you would like to silence the fan, such as when sleeping!
A thermometer is helpful to monitor your refrigerator's temperature. We especially like the AcuRite Refrigerator/Freezer Wireless Digital Thermometer.
Additional info: Cool... and wireless
SilverGate is offline   Reply With Quote
Old 06-03-2016, 06:38 PM   #4
AWCHIEF's Avatar
2006 23' Safari SE
Biloxi , Mississippi
Images: 33
If the fridge is not on there is no reason to have the fan on.
MICHAEL
Old 06-03-2016, 06:49 PM   #5
Sag Harbor , New York
Your owner's manual should give you the basics.
Old 06-04-2016, 12:42 PM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
PS: In case you are wondering... the fan is not inside the fridge ... it's located behind the actual fridge....in the fridge compartment accessible from the outside... They get noisy over time, but can be easily replaced with a better/quieter fan (this is discussed quite a bit here on the Forums...). We usually turn ours off at night.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
TBRich is offline   Reply With Quote
Old 06-04-2016, 08:12 PM   #7
CruizinDux's Avatar
Washington , Missouri
Am I missing something or misreading this? If the fan switch is on with current running thru it to the thermostat, yet the refer is off and I would think would be cold (the fins and location of the thermostat...assuming there is one), is there a failure of the thermostat and seeding power to the fan.
CruizinDux is offline   Reply With Quote
Old 06-04-2016, 08:14 PM   #8
CruizinDux's Avatar
Thanks, this is a great product, not always having to open the door to check the temp.
Thx
b
Old 06-05-2016, 02:22 AM   #9
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
The fan doesn't have anything to do directly with the running/operations of the fridge...it's an "assist" to move warm air out of the compartment behind the fridge so that the fridge can operate more efficiently. This switch is particular to 19'ers...not sure if any of the newer models have a manual switch. Some models have exterior fans that cannot be disabled by a manual switch (like the 23's I know). Some folks with this situation have installed so they can turn the fan off because it can be noisy. (When the fridge it turned off there is no reason to have the switch turned on. If the switch is on and the fridge is off, high ambient temps enough to trip the thermostat to make it run.)
AirForums #21900
PastPrez, 4CU/WBCCI
Old 06-05-2016, 03:38 AM   #10
Our 2014 FC20 also has the manual switch for the cooling fan, which many are replacing with a quieter computer fan, as mentioned before, and as discussed on other threads.
FYI and FWIW
Recomendations near red Rock in Las Vegas coairstream On The Road... 11 01-31-2016 11:28 PM
Boondocking near Red Rock Canyon State Park in CA Knuff Boondocking 6 12-19-2013 09:57 PM
Leak near tail light, but it's not the tail light adwriter73 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 03-31-2013 11:34 AM
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 01:18 PM
Tail light red, green, yellow wires? PKelley Electrical - Systems, Generators, Batteries & Solar 2 06-08-2005 07:28 AM
