Old 02-13-2017, 11:58 AM   #1
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Question Recommendations on Table Pedestal
So I'm currently remodeling our 2007 International, we're doing a grand lounge remodel. And considering using the Springfield 3-Stage Air-Powered Table Pedestal.
Man are they pricey. And I plan on using two!
The thing is, I really like the idea of being able to remove the table. And I'm curious if anyone has seen or used a collapsable storable pedestal.
So far all the ones I've found are fixed height:
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 04-25-2019, 09:13 AM   #2
2018 27' Flying Cloud
Forest Grove , Oregon
One or Two ?
[QUOTE=BoldAdventure;1911557]So I'm currently remodeling our 2007 International, we're doing a grand lounge remodel. And considering using the Springfield 3-Stage Air-Powered Table Pedestal.
Did you end up using one, or two, pneumatic pedestals? My new walnut table is 7/8" x 33 x 35.
ForestStranger is offline   Reply With Quote
Old 04-25-2019, 09:54 AM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
we removed the pedestal and went with the lagum table mount
now we have no pedestal to block our feet.
We are very happy . the install was very easy
http://www.airforums.com/forums/f295...le-172239.html
waninae39 is offline   Reply With Quote
Old 04-25-2019, 10:17 AM   #4
It depends on your application which would work better, but I give +1 on Lagun for its sheer versatility.
I have two mounting brackets in our Airstream Interstate - one in the front where my passenger seat swivels, and one in the rear where I can work from the couch.
Front office quad (pics taken before I rounded the corners of the table top):
Rear office:
Edit: Another view of the rear mount. The table top can be pushed out of the way without needing to be removed.
Table top storage - hangs on back of wet bath door:
Old 04-25-2019, 11:00 AM   #5
"Silver Shrek"
drairstream's Avatar
2000 27' Safari
Crestwood , Kentucky
I like the Springfield
drairstream is offline   Reply With Quote
Old 05-02-2019, 11:47 PM   #6
Journeyman
2016 25' International
Deerfield , Massachusetts
I'm doing mine now and ordered just one of the Springfield units. Seems VERY sturdy, but ask me in a week when I get it I installed!
Liebroc Industries was cheapest (shipped) that I could find on the pedestal.
(Call me crazy, but I will first try to install the pedestal with VHB tape. If it wobbles, then I'll consider screwing into the floor as a backup plan. )
thiel is offline   Reply With Quote
Old 05-09-2019, 08:14 AM   #7
2016 25' Flying Cloud
2016 27' International
Saint Paul , Minnesota
We have a international 27FB and ordered two more of the collapsable legs from www.kitchesource.com and will install them by the back wall. Now we will only have to hang the table top in the notches and the three legs will support the table. We have a smaller solid wood table top now that we like to exchange with the original when the grandkids spend the night. The two legs cost us under $80.00.
tooleshop is offline   Reply With Quote
Old 05-09-2019, 08:43 AM   #8
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Take a look at Bob Miller's thread on the motorhome forum. He has sourced one of the motorized pedestal, as sold by Airstream for $2600 for a tenth of that from Japan.
martin300662 is offline   Reply With Quote
Old 05-09-2019, 08:59 AM   #9
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
I sourced one made in Germany through a RV parts dealer in France.
The plywood top in these photos was just to test the functionality. The horizontal movement lock works against the bottom of your table top.
Name:	Table Pedestal Normal Position.jpg
Sliding to the side:
Name:	Table Pedestal Slid To Side.jpg
Sliding front/back:
Name:	Table Pedestal Slid Back.jpg
Rotates about 35 degrees to either side:
Name:	Table Pedestal Rotated Postion.jpg
Here's the website.
https://www.mecatechnic.com/fr-FR/pi...mm_CQ10184.htm
They will give you a quote for freight before ordering. Surprisingly,
my freight was only 38 Euros. They shipped with TNT Freight, which is owned by FedEx. It only took about 3 weeks to arrive.
I would make one recommendation if you get this unit. The lock cable where it comes out of the pedestal has a strap to position it. Remove the strap and let it come out perpendicular from the base. Re-position the strap on your table top. The cable works better if it has 'gentle' curves. the factory retainer is very close to the end of the cable and I believe it puts strain on the cable.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Any recommendations on a marine aluminum adjustable table base pedestal? Spork General Interior Topics 1 06-02-2015 10:24 AM
Telescoping Table Pedestal source? redreefet Cabinets, Counter Tops & Furnishings 2 12-25-2010 12:30 PM
Wanted B-van Pedestal table 2RUSS@ATT.NE Member Introductions 4 09-22-2009 08:54 AM
1986 345 AS MH Pedestal Table Jim Tyrney General Motorhome Topics 0 03-29-2004 09:45 PM
Pedestal Table eraffety Airstream Motorhome Forums 7 11-08-2002 08:02 AM
