Old 10-28-2015, 04:28 AM   #1
1972 Argosy 22
Shalimar , Florida
Rear kitchen
Looked at a lot of renovated interiors lately, have never seen a wraparound galley area in the rear. We are pondering just that, are there cons to this idea that we're not thinking of? The rear window is below the ideal height for a kitchen countertop, but we can adjust to that (make a dip in the countertop under the window). Basically stovetop (no oven) and bar sink Curbside, micro and storage streetside, fitting the plumbing connections and converter as well. Is this a good idea? Thanks for help past and present
Andersojd is offline   Reply With Quote
Old 10-28-2015, 07:06 AM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
It would be easy to cause a very adverse effect on the trailer's towing characteristics by installing heavy items (which include kitchen fixtures and appliances) in the rear of the trailer. Having the correct amount of the trailer's weight on the hitch is critical in avoiding dangerous sway.
mimiandrews is online now   Reply With Quote
Old 10-28-2015, 07:23 AM   #3
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
The 61-63 Bambi has the kitchen in the back. That is the reason for the small window in the back.
Name:	100_7194 (640x480).jpg
ID:	251176   Click image for larger version
Name:	100_7303 (640x480).jpg
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 10-28-2015, 09:29 AM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
These trailers are not quite the "blank canvas" that you might think they are. They fit together like puzzle pieces, and just because you have removed the pieces doesn't mean its easy to start over. For example, You will have various holes in the shell, like for the plumbing vent stacks, the stove vent, the refrigerator chimney, the furnace, and the water heater. If you decide to move all these things around, then you have to patch up the old holes, and create some new ones. Closets and cabinetry are strategically located to hide vent pipes, and ugly appliances (water heaters, converters, furnace, etc.).
The weight issue is a major one as well, and not only for the quality of the towing experience. The 70's era trailers are already known for rot and rear end separation. Positioning a lot of heavy appliances back there is only going to aggravate the situation.
Good luck!
Old 10-28-2015, 09:33 AM   #5
Mission , Texas
I wouldn't want a rear kitchen - too much potential tossing around.
nrgtrakr is offline   Reply With Quote
2007 interstate rear kitchen pros/cons Mletke Sprinter and B-van Forum 7 08-08-2015 01:49 PM
1958 vintage airstream traveler 18' with rear bed full 50's kitchen & bathroom eBay Watch Airstreams on eBay 0 12-24-2013 07:50 AM
1958 vintage airstream traveler 19' with rear bed full 50's kitchen & bathroom eBay Watch Airstreams on eBay 0 12-17-2013 11:30 AM
Airstream Interstate 22 w/Rear Kitchen and PT Cruiser Tow Car eBay Watch Airstreams on eBay 0 10-10-2011 05:40 AM
2010 airstream 20ft flying cloud* rear kitchen eBay Watch Airstreams on eBay 0 06-25-2010 12:10 PM
