Old 07-18-2013, 05:10 AM   #1
LFC
Memphis , Tennessee
Rear curtains stained ?
Anyone know of a remedy ?
LFC is offline   Reply With Quote
Old 07-18-2013, 05:32 AM   #2
247stream's Avatar
1986 25' Sovereign
Marietta , Georgia
what kind of stain, how big a stain, on what color curtains? sometimes stains can be removed with hydrogen peroxide...google it and you'll find lots of info on that. sometimes dyeing can cover a stain or at least lessen its appearance if you do it the right color. you can also 'craft' over a stain depending on size and location. you'll have to give more info to get a better idea of options
WBCCI# 1558
2016 Ram 1500 Crew Cab 5.7 Hemi
247stream is offline   Reply With Quote
Old 07-18-2013, 05:53 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Fix the water leak, The stains, I have found, do not dry clean out.
Old 07-18-2013, 07:28 AM   #4
jhart657's Avatar
2007 25' Classic
1993 21' Sovereign
Elm Grove , Wisconsin
Water stains can be removed with Oxi Clean.
I had the same water stain problems on my '93 21ft. Sovereign. I hand washed the drapes in a bucket using Oxi Clean. A toothbrush is great for working in the Oxi Clean directly on the stained areas. Rinse in clear water and let them drip dry on a clothes line. My window coverings looked like new. Understand, this worked with my '93 fabric. Whether your window coverings are made of similar material is an unknown.
Good luck!
Juergen
jhart657 is offline   Reply With Quote
Old 07-18-2013, 08:22 AM   #5
LFC
Memphis , Tennessee
I don't think they are water stains they look more like light brown sun stains. They are located in front of the rear window. My Airstream has been stored under a cover it's entire life and shows no sign of any leaks.
Old 07-18-2013, 08:27 AM   #6
Lily&Me's Avatar
Normal , Illinois
Ditto on Juergen's oxyclean recommendations.
Even if they are not water stains from leaks, could also get these from humidity inside if the curtains have contact with the windows.
Regardless of the origin of the stains, oxyclean is likely to be your best bet, IMO
Maggie
