Old 06-18-2011, 05:25 PM   #1
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Rear bath endcap removal
1 do you have to remove the rear window to get it out
2 how the @&$)( do you get it out of the trailer
Darkspeed is offline   Reply With Quote
Old 06-18-2011, 05:41 PM   #2
Everything that goes into an Airstream, goes in or out via the entrance door.
Old 06-18-2011, 06:19 PM   #3
Darkspeed's Avatar
1972 31' Sovereign
Thanks Andy it must be super flexible once down. Window need to come out?
Old 06-18-2011, 06:43 PM   #4
Yes, it's very flexible.
No, no windows come out.
Keep in mind, when the shell is completed, it is then water tested at the factory.
Then, and only then, are the guts added.
Old 06-18-2011, 08:58 PM   #5
Mr & Mrs S's Avatar
Newton , Texas
Be Careful
Be very careful when handling the end caps. Yes the top of the end cap where it is domed is flexible, BUT try your hardest not to let it bend. I would do this job with a minimum of two ppl. Three would be the best. Two to hold each and and one to drill out the rivets to let it down. I on the other hand done it bymyself and ended up with a very small crack on the upper left hand corner of the cabinet. Trust me dont flex it no more than what is needed.
I also removed the couch from the front of the trailer which gave me loads more room to help position it out the door. It will fit but have plenty of help and in no way force it.
MR. & MRS. S
--Streamin & Gleamin--
Airstreamless, but havent lost our passion for them. Currently looking for the next project!
Mr & Mrs S is offline   Reply With Quote
Old 06-18-2011, 09:26 PM   #6
Darkspeed's Avatar
1972 31' Sovereign
Thanks guys!
Need help with Rear Bath falling out. Slowride66 Repairing/Replacing Floor &/or Frame 32 06-17-2012 05:10 PM
Painting Rear bath options SilverHoot General Interior Topics 11 04-07-2011 08:31 AM
Replacing the floor in a rear bath elkie2331 Repairing/Replacing Floor &/or Frame 4 04-04-2011 07:35 PM
1976 Rear Bath Lights Eagle & Bear Electrical - Systems, Generators, Batteries & Solar 5 03-26-2011 04:20 PM
