Old 12-09-2004, 12:29 PM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
re-install ceiling panel
had to take down the ceiling panel to do some leak repairs...after drilling out all the rivets, I found that the moldings on either side (that run front to back along the edges of the panel) are riveted to the wall panels behind the ceiling panel itself...so there's no way to drill them out. I had to slip a putty knife between the molding and the wall panels, and snap the shafts off by tapping with a hammer. ok..no problem. Now, how do I put it back? should I just rivet the molding strips back the way they were, and hope that the ceiling panel can bend in a "U" shape enough to get the edges to slip into the molding piece? don't want to crease it.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 12-09-2004, 12:35 PM   #2
RichardT's Avatar
The answer to your question is yes. Put both edges in with the piece curved down and then pop it up into place.
RichardT is offline   Reply With Quote
Old 12-09-2004, 07:24 PM   #3
Tinsel Loaf's Avatar
Would it make sense to pop in a flat screw type female rivet and then just use a flat screw to secure moldings in place. That way you could remove the moldings at a future date if ever needed.
Tinsel Loaf is offline   Reply With Quote
Old 12-10-2004, 08:49 AM   #4
Tinsel Loaf.
The screws would also come out , by themselves, when traveling.
Old 12-11-2004, 02:26 AM   #5
qqq
qqq's Avatar
The screws won't come off when traveling if you use "loctite" threadlockers
qqq is offline   Reply With Quote
replacement panel maznblu Ribs, Skins & Rivets 4 09-18-2002 05:45 PM
Control Panel indicators smily Electrical - Systems, Generators, Batteries & Solar 3 07-26-2002 03:55 PM
Dented panel replaced Jim W Ribs, Skins & Rivets 1 07-08-2002 07:07 PM
Display Panel ALANSD Mechanics Corner - Engines, Transmission & More... 4 06-08-2002 03:28 PM
61 Bambi Panel Replacement 61BambiCanada Ribs, Skins & Rivets 0 06-07-2002 09:41 AM
