Old 09-22-2013, 01:17 PM   #43
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by mstephens View Post
Well done conversion. I am wondering though if the head end of the beds could be done differently. I like to sit in bed and read, which means propping up against a head board of some sort. The curved walls don't make that too easy, although you can pile pillows I suppose. What I was wondering is if there is enough length to allow a squaring off at the head in some way, to make it more like a headboard? (Sitting here without a ruler, or I would go measure!)
I wish we had given more consideration to twin v. queen.
Something like these might work.
BackJack XL Floor Chair from Home Theater Express
Old 09-22-2013, 01:32 PM   #44
Rollster's Avatar
Saint Augustine , Florida
Thanks so much for the information, Evan! You precisely answered my questions. And you even confirmed in another post my thoughts about buying 6" foam for the beds. I hope you had a good last trip. We're in Florida, so our camping season is just beginning, but the project may delay any trips for now. Again, thanks! Carol
Carol, Aboard "Aggie the DreamStream"
WBCCI# 5248
Rollster is offline   Reply With Quote
Old 12-02-2013, 10:57 AM   #45
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I hope you are still following this, even though I am several months late to the party. This is an incredible job! We are looking for our first AS and are pretty sure we want the twins, but they seem to be in short supply in the 25FB models at this time. I think I can do this. Buying a queen version and converting if necessary would let us be sure about which we prefer.
I have also been reading about problems with window leaks and sub-floor rot. I noticed that you talked about installing window drains. I wonder if you could elaborate a little on the what/why/how of doing that, as it seems the leaks are a pretty common problem.
Thanks!
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 12-02-2013, 11:30 PM   #46
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Based upon a bad night's sleep at the selling dealership lot, we replaced the OEM 7" mattress in our 2013 25FB International Serenity before our first trip with an 8" mattress from Rocky Mountain Mattress:
The Sunrise? 8" Memory Foam Mattress with Bayer Technology
The 8" mattress filled out the Airstream Factory 600 thread count sheets so they were not loose. We slept so well on this mattress that we ordered two in twin sizes for the new trailer.
Note a higher/thicker mattress could have issues by being higher than the bedside tables or openings in the cabinets beside the queen beds in 31' models.
Old 01-07-2014, 09:57 PM   #47
2010 25' FB Flying Cloud
Davenport , Iowa
Somewhere I saw where someone had made a template of the curve when cutting plywood for the twin bed in the conversion. I have been searching and cannot find that thread. Any help?
Now you know how I am spending the winter months and what I am getting new for my Airstream.
Mike
Airtandem is offline   Reply With Quote
Old 01-08-2014, 06:33 AM   #48
Coaster's Avatar
Mike
Name:	ImageUploadedByAirstream Forums1389187861.081433.jpg
ID:	203193I drilled a hole in a paint stick for a pencil to mark the pattern.
Coaster is offline   Reply With Quote
Old 01-08-2014, 07:30 AM   #49
switz's Avatar
2014 31' Classic
Images: 8
See post #38 above for the mattress drawings.
Old 02-11-2014, 11:20 PM   #50
eheffa's Avatar
2008 25' Safari FB SE
Victoria , BC
Thanks!
Hi there,
Sorry to have missed your posting.
I documented the window drain conversion here:
http://www.airforums.com/forums/f456...ls-107690.html
As per a few suggestions from other posters there could be simpler fixes than what I did. My modification seems to be working just fine but it was definitely more complicated than just drilling out the corners.
-evan
eheffa is offline   Reply With Quote
Old 02-13-2014, 05:55 AM   #51
Coaster's Avatar
Finished the conversion.Click image for larger version
Name:	ImageUploadedByAirstream Forums1392296006.722041.jpg
ID:	205490Click image for larger version
Name:	ImageUploadedByAirstream Forums1392296022.092949.jpg
ID:	205491Click image for larger version
Name:	ImageUploadedByAirstream Forums1392296035.124702.jpg
ID:	205492Click image for larger version
Name:	ImageUploadedByAirstream Forums1392296051.185311.jpg
ID:	205493Click image for larger version
Name:	ImageUploadedByAirstream Forums1392296108.330433.jpg
ID:	205494Click image for larger version
Name:	ImageUploadedByAirstream Forums1392296124.953296.jpg
Old 02-13-2014, 06:03 AM   #52
Coaster's Avatar
Name:	ImageUploadedByAirstream Forums1392296568.804818.jpg
ID:	205496Click image for larger version
Name:	ImageUploadedByAirstream Forums1392296628.546175.jpg
Old 02-13-2014, 07:12 AM   #53
eheffa's Avatar
Victoria , BC
Originally Posted by Coaster View Post
Very nice job Coaster!
The night table looks great. The lamp adds a lovely finish to your job.
Looking at the configuration of your unit with fewer windows in the forward BR, makes me think that although the wrap around windows of our version seem desirable, it's actually better to have less glass in the sleeping area.
Nicely done.
Enjoy your new camping season!
-evan
Old 02-13-2014, 08:57 AM   #54
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Very nice work, Coaster!
My only suggestion would be, to go back and take better pictures. Those posted (of the finished work) just don't do your great work justice!!!!
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 05-28-2014, 10:19 PM   #55
2008 27' Safari FB SE
Akins , Oklahoma
Images: 20
I always over build. Pictures soon enough I guess.
sequoyah101 is offline   Reply With Quote
Old 05-30-2014, 08:18 AM   #56
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
your conversion turned our very well, nice job
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Queen to twin conversion Roadtoaster General Interior Topics 8 11-23-2014 10:54 AM
FB N/S Queen to Twin Conversion Al and Missy General Interior Topics 2 12-06-2013 08:17 PM
Int'l 27-twin bed vs queen; convert to queen Soul Food II General Interior Topics 1 03-20-2013 10:07 PM
Twin/Queen Conversion - Idea Foiled Again General Interior Topics 6 07-05-2008 10:25 AM
Conversion of twin beds to queen tslanier Cabinets, Counter Tops & Furnishings 5 01-23-2007 06:34 AM
