Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 10-25-2004, 01:00 PM   #1
Profile:
Pullout SofaBed Question
We have a 27' 1974 Overlander and the screws that secure the sofa bed to the wall keep pulling out of the wall, and it seems as if they weren't properly anchored to the metal framing. Being a new Airstream owner I'm not sure how the framing is on that particular year. Would it be sufficient to use a toggle bolt to anchor this, or is there another way of doing this? Any help would be appreciated.
Todd
tgump is offline   Reply With Quote
Old 10-25-2004, 01:18 PM   #2
RichardT's Avatar
Profile:
Todd
If a larger size but same length screw was used would that work?
If you do use toggles or anything else just make sure that the one you use is not so long as to hit the exterior skin.
RichardT is offline   Reply With Quote
Old 10-25-2004, 02:18 PM   #3
Patriotic
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
I've noticed the same thing since I started using the pull-out regularly. there just isn't much holding it down. when I first investigated, I thought this was some sort of mickey-moused retrofit...then I realized that there are no other holes anywhere, either in the couch framework or the wall...this is the way the factory did it. and its just not adequate for a big heavy lag screw. the thin interior skin is all it has to grip, (there's no "framing" involved, as far as I can see), and over time, the holes distort. I haven't thought of a "fix" yet...perhaps your idea of a toggle bolt of some sort will work.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 10-25-2004, 04:07 PM   #4
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
There is framing back there...
There is framing back there but I don't recall if the sofa is supposed to be fastened to it or not. Mine was pulled out on one end, I have the entire front end disassembled at the moment, I plan on riveting some thick pieces of aluminum behind the skin where it pulled out that last time. I might even tack weld a bolt onto the plate to keep it from happening again
Aaron
WBCCI #2449 AIR #2495
wahoonc is online now   Reply With Quote
Old 10-25-2004, 06:34 PM   #5
Profile:
Sofa Bed
There is plenty of room underneath right now, so I think I might try to design some sort of wood framing or box and mount it to the plywood floor. I'll design it so I can still have use for the storage drawers underneath. That way I won't disturb the interior skin. There just isn't enough strength or support there for us fat guys! That should help. What do you think?
Aaron
Old 10-25-2004, 06:43 PM   #6
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
I have fixed the side bed in both of the coaches I owned that had one. The bracket that is attached to the inner wall is screwed into the inner skin. I normally add 2 self tapping screws thru the rear brace into each of the ribs that it crosses. The ribs will be at the rivet lines. This has been a permanent fix in each case.
If it is the front couch it is only attached at the corners. This is also a weak spot, there are no ribs. I have attached a wide strip of flat bent aluminum stock to the inner skin curved to match, with a bunch of rivets and then screwed into the plate. This spreads the strain and offers a better bite for the screws.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Tri Axle Question HowieE Axles 30 10-27-2004 08:44 PM
Plumbing connection question clowman Fresh Water Systems 1 06-28-2004 09:19 PM
Question regarding GVWR joshua32064 Tow Vehicles 6 10-19-2003 07:57 PM
Rust Question drober05 Airstream Motorhome Forums 6 10-05-2003 02:09 PM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 05:01 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
