Old 05-06-2015, 08:38 PM   #1
bellastream's Avatar
1969 31' Sovereign
Auburn , Washington
PROGRESS on my 31' 1969 Sovereign!!!!!
Hello everyone I have made great progress fixing a rotten floor under the fridge, and remodeling the front interior of my Bella. I got the AS last August camped in it twice then tore it apart. Here are some pics of my progress on the inside.Click image for larger version
ID:	237922 This is of the hole I patched under the fridge. Click image for larger version
ID:	237923 Skin back on and new subfloor. Click image for larger version
ID:	237924 New flooring sheet vinyl from Lowes. Click image for larger version
ID:	237925 Click image for larger version
ID:	237926 front end furniture out of a 70 something Sovereign I found on Craig's list. I also put in a new fresh water system. Click image for larger version
ID:	237927 Click image for larger version
ID:	237928 Click image for larger version
ID:	237929 cool lights I added. Click image for larger version
ID:	237930 Click image for larger version
ID:	237931 More pics of installed 70's furniture. I was pleased it fit perfectly.
bellastream is offline   Reply With Quote
Old 05-06-2015, 09:15 PM   #2
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
It's a good feeling to make progress, huh? Looking better and better!
Those cool lights are......... COOL!
ďWhatís good for me may not be good for the weak minded.Ē
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 05-06-2015, 09:23 PM   #3
1969 31' Sovereign
Auburn , Washington
They are RGB led lights I got from Ebay. They come with a remote and you can blend the colors to make any color you want. One problem I ran into with them was the adhesive tape they come with is so thin it doesn't provide enough insulation between the light strip and the aluminum skin and the lights were shorting out. I ended up using some thicker 3m double sided tape.
Old 06-20-2016, 08:17 AM   #4
1969 31' Sovereign
Auburn , Washington
well there are some new additions to the trailer this year. The most notable being my brand new dometic awning. When I found out they made curved arms for the 69 up AS I had to jump on it.
Old 11-28-2016, 05:29 PM   #5
1969 31' Sovereign
Auburn , Washington
ID:	276135Click image for larger version
ID:	276136 well I wanted to add this to my project page. These are my outside speakers I made. They are made out of 2 old time drive in movie speaker castings. I put new modern speakers in the casting and attached a 6 foot cord with a phono plug on the end. The genius part of the whole thing was I installed a 1/4 phono jack into the window sill and ran the speaker wires inside the wall to the frame. All you have to do is open the window plug in the speaker and hang it on the window sill or awning arm and you got outside speakers without needing to put any holes into the outside of your trailer. Also I think they match the trailer quite well.
Old 11-29-2016, 10:10 AM   #6
Pygmypoacher's Avatar
Black Diamond , Washington
Originally Posted by bellastream View Post
Attachment 276135Attachment 276136 well I wanted to add this to my project page. These are my outside speakers I made. They are made out of 2 old time drive in movie speaker castings. I put new modern speakers in the casting and attached a 6 foot cord with a phono plug on the end. The genius part of the whole thing was I installed a 1/4 phono jack into the window sill and ran the speaker wires inside the wall to the frame. All you have to do is open the window plug in the speaker and hang it on the window sill or awning arm and you got outside speakers without needing to put any holes into the outside of your trailer. Also I think they match the trailer quite well.
Brilliant mod!
Pygmypoacher is offline   Reply With Quote
Old 11-29-2016, 10:27 AM   #7
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Did you lay the new flooring directly over the subfloor or put a layer of Luan in first.?
What do you do about the elevator bolt heads?
Dingo Girl is offline   Reply With Quote
Old 11-29-2016, 10:31 AM   #8
1969 31' Sovereign
Auburn , Washington
I did a layer of Luan first than the new flooring.
Old 11-29-2016, 10:32 AM   #9
1969 31' Sovereign
Auburn , Washington
Originally Posted by Pygmypoacher View Post
Brilliant mod!
sovereign
'78 Sovereign Restoration in Progress - Seeking Replacement Refrigerator Advice lhkrueger Refrigerators 10 05-10-2013 10:22 PM
1975 31ft International Sovereign progress Okotoks 1974 - 1979 Sovereign 3 07-17-2012 12:52 AM
1969 Sovereign :: 1969 Airstream Sovereign evers310 Airstream Registry Discussions 0 08-19-2011 08:31 AM
Progress on the 1976 Sovereign juel 1974 - 1979 Sovereign 33 08-04-2008 08:11 AM
Cat's FIRST Photos of BEARs progress Cat General Interior Topics 3 11-13-2002 09:46 PM
