Old 06-26-2011, 06:01 PM   #15
reinergirl's Avatar
Hollis , New Hampshire
Thanks again for all the comments Once I saw what the discount was ($100) I decided that having extra was better so I ordered 2 full rolls (one free). The shipping for one roll is $65 and the second shipped free..... so if I had to order more it would have negated my savings. At least it will be ready to go when I am!
reinergirl is offline   Reply With Quote
Old 07-07-2014, 12:24 PM   #16
ekstarr's Avatar
1952 17' Clipper
Marina del Rey , California
Perforated Prodex or not?
So grateful to have so many ambitious DIY-ers pioneering the road ahead for the rest of us.
I am about to purchase Prodex for my 1952 Silver Streak Clipper. Do you guys recommend PERFORATED Prodex or the NON Perforated Prodex. The website fails to explain the difference in benefit.
Thanks!
ekstarr is offline   Reply With Quote
Old 07-07-2014, 09:06 PM   #17
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Difference - the perforated allows a limited amount of air to escape otherwise sealed areas. Prodex total is an unbroken foil face making it a vapor-barrier that can both trap water left by intrusion or produce moisture itself via condensation from temperature differences. When vapor barriers are put into houses/sheds/etc. they are meant to face the 'conditioned' living space, the heated/cooled spaces, to reduce the possibility of condensation across temperature gradients so they produce a perforated 'wrap' that goes over top of the existing structure and breathes to help protect against wood rot or steel structures rusting.
Ah, so... since the aluminum shell is a nearly perfect vapor barrier and we toll tirelessly to keep them leak free the enemy would be from within, humidity from cooking, bathing and respiration finding its way deep in the walls and condensing out with temperature changes - so we don't want perforated...
1968 Avion C11 Truck Camper restoration jforb Vintage Kin 310 01-04-2016 06:20 AM
The correct Elevator bolt size is? Top Repairing/Replacing Floor &/or Frame 17 11-30-2011 07:20 AM
My insulation progress....The triple layer combo ddstech General Interior Topics 46 08-25-2011 02:00 PM
1Rookie - 1969 1Rookie 1965-1969 Sovereign 14 06-17-2011 05:14 PM
A/C Sizing lpgasguy Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-02-2011 02:24 PM
