Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 01-19-2015, 06:53 PM   #1
1975 31' Sovereign
Pass Christian , Mississippi
Prodex Installation?
Is there a thread someone can point me to that explains the best practices for installing Prodex insulation to the inside of my 31' 1976 Sovereign trailer shell?
kimball1966 is offline   Reply With Quote
Old 01-19-2015, 07:23 PM   #2
DFlores's Avatar
1968 22' Safari
Buda , Texas
Prodex
There will be many opinions on this subject. I can show you what we did starting at post #67 http://www.airforums.com/forums/f192...-100750-5.html
Hope this is helpful
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 01-19-2015, 09:13 PM   #3
1975 31' Sovereign
Great post! Just what I was looking for! So the first layer was set with carpet tape up against the outer skin, then 1/2 foam board strips with a second layer and you had some left over from a single roll? Was that a 48"x175' roll? I wonder if it would be enough to do mine?
Old 01-19-2015, 09:15 PM   #4
DFlores's Avatar
1968 22' Safari
Buda , Texas
My trailer is only a 22' trailer and the roll you describe is what I bought
Sent from my iPhone
David & Diane
DFlores
David & Diana
Old 09-01-2015, 02:58 PM   #5
Leesburg , VA
Sent from my iPhone
David & Diane
David and Diane did you get the 48"x175' roll? Did you do a single layer or double layer with that length?
cecreighton is offline   Reply With Quote
Old 09-01-2015, 09:07 PM   #6
DFlores's Avatar
1968 22' Safari
Buda , Texas
Yes we purchased the 48x175
We installed a double layer
Had some small pieces left over to insulate the fender wells
Sent from my iPhone
David & Diane
DFlores
David & Diana
Old 09-01-2015, 09:18 PM   #7
1979 23' Safari
Wayland , New York
I used a 48"x175' on my 23', 2 layers and came up a little short and finished with reflectex from blue big box. I was very careful on cuts and very little waste. If you're doing a 31' trailer I'd definitely get 2 rolls, 1 won't be enough, based on my install I'd bet you'll have very little left from 2 rolls if you do 2 rolls.
You want the biggest air space between the outer skin and first layer of Prodex. Most people use 1/2" ridged foam to space the Prodex from the skin and between layers. Outer skin, 1/2" air space, Prodex, 1/2" air, second Prodex layer, inner skin.
Old 09-01-2015, 09:26 PM   #8
1979 23' Safari
Wayland , New York
Here's from another post I wrote.
I did this last summer and this spring. Used Prodex mostly , but came up a little short and finished up with reflectex(silver bubble wrap you see at lowes and Home Depot). My 23' used one full Prodex roll which was 48"x 170' or some length close, and a few rolls of 16" reflectex. They sell wider reflectex, but for what I needed to finish up it was a good size. Both were pretty easy to work with, the Prodex cut a little easier.
Key is getting the trapped air layers, you don't want it going right against the skin.
I did 2 layers of the insulation. The process involved cutting about 5,000, 1"x1" square pieces of 1/2" thick rigid insulation. Yep, 5,000, a little over a full sheet got cut up into little cubes. I set up a little station and would use a razor knife to cut a bunch of 1"x48" strips. Then just slice 1" pieces and feed another inch to the razor. Set up a little 'jig' on a small 2'x4' piece of plywood. Eventually cut through the plywood with the razor cutting in the same spot over and over.
Each section between horizontal and vertical ribs gets done individually do you have to measure and cut the Prodex or reflectex to fit each one.
First I would go to each section and take some of the 1" blocks, I would put a big dab of polyurethane sealant/adhesive(used black poly roofing sealant) on one side of the block and adhere some around the perimeter of the section and then some somewhat randomly in the interior portion, spaced to minimize conductive heat transfer, but enough so they would hold the insulation off the skin and create a air space. I'd let the poly set up over night then put a layer of insulation in. Then I hot glued(so I didn't have to wait for poly to set ) blocks to the face of the next layer of insulation, around its perimeter and spread out in the middle, then put that over the first layer. Each piece of of insulation was cut to fit snug at the edges of each section. You'll quickly realize that the ribs look straight and parallel but often aren't, do lots of measure and cut.
If you can imagine the layers from outside-in, it would be outer skin, foam block, insulation, foam block, insulation. But the foam block layers were really mostly air.
All the wiring got sandwiched between the layers of insulation so it wasn't against the outer or inner skins directly. Figured this will help keep it cooler and last longer and protect from chafing.
Took a lot of work, especially with my OCDism, and the way I did a few things, but I am very happy with it. No insulation can keep a closed up trailer sitting in the sun from getting hot inside. But if I go down to work on it and open up the windows and put the awnings out. It will easily stay very close to outdoor ambient. Haven't had a AC unit on the trailer for almost 2 years working on her so it definitely helps keep cool. No furnace either, When it's cold I turn on a small catalytic heater and it warms up quick(10 min), then I'll usually have to turn it off to keep from getting to hot, running it for 5-10 min an hour to keep it warm.
You can use foam strips instead of little cube blocks.
Here's the thread
http://www.airforums.com/forums/f46/...n-13619-2.html
Old 09-01-2015, 09:30 PM   #9
1979 23' Safari
Wayland , New York
You want the Prodex to be snug in each cavity then seal edges with aluminum foil tape.
If you haven't yet make sure there are some drain holes in the c channel. The Prodex is waterproof so will channel leaks straight down there for the most part so you may not realize you even have a leak for a while. The old fiberglass would let it soak through and often be seen coming from seam between interior skin panels.
Old 09-05-2015, 09:19 AM   #10
DFlores's Avatar
1968 22' Safari
Buda , Texas
I will have to disagree with posts about "do not place against outter skin", ours is directly against outter skin and we just went thru an August in Texas in direct sunshine, no shade, with a string of 100+ temperatures and our little Safari was quit comfortable with interior temperatures around 74 when outside was over 100. I have consistently been getting 25+ degree difference from outside temperature.
Placing first layer against outside allows room for air gap for wiring then second layer of prod ex, then a one half inch layer of Rmax panel for sound insulation.
Sent from my iPhone
David & Diane
DFlores
David & Diana
Prodex sizing? reinergirl General Interior Topics 16 07-07-2014 09:06 PM
Installing Prodex under the floor cole3444 Repairing/Replacing Floor &/or Frame 6 03-15-2014 10:34 AM
Prodex: does it work? purman General Interior Topics 6 07-20-2012 05:58 PM
Anyone needs Prodex Insulation ASNomads General Interior Topics 0 12-15-2011 11:45 AM
ProDex between new floor and frame? Comments? Wabbiteer Repairing/Replacing Floor &/or Frame 3 10-18-2011 05:27 PM
