07-07-2012, 08:47 PM
1971 23' Safari
Cranbrook
, British Columbia
Pretty sure i just made a big mistake!
Just finishing up my 71 safari interior restore, getting the bathroom put back together after replacing the floor and I find what looks to be fibre optic cable that in my rush tearing the trailer apart I cut. Obviously when I cut it a month ago I had no idea it was fibre optic, had no idea at the time these trailers had it.
Anybody have any ideas how I can fix this, or maybe a alternative to running the fibre optic cable? Pretty sure you cannot splice this stuff together.
07-07-2012, 10:04 PM
Ottawa
, Ontario
It's purpose is to confirm that your rear taillights are operating. The sensor sits in the taillight housing, and turning on the lights illuminates the lens in a rear side marker made especially for this.
I agree you can't repair it, but where to get a new on is a really good question...
Stay Calm. Be Brave. Wait for the Signs.
07-07-2012, 10:11 PM
1968 28' Ambassador
Cedaredge
do you need it? is it part of the lights?
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
07-07-2012, 10:27 PM
1974 Argosy 20
Kooskia
, Idaho
The fiber optic to see if the tail/stop lights were working was a nice idea, and worked fairly well, but certainly is not a disaster if it is not working or repaired. In fact, since many are putting LED lights on their rigs, it is virtually impossible to make the old fiber system work with any conversion lights. I simply would not worry about it unless you are making a totally original museum piece AS.
07-08-2012, 12:45 AM
1988 25' Excella
Trumbull
, Connecticut
Fiber Optic repair
Hello. I had an old Cadddy that had the fiber optic going to the tail lights, turn signals and one more place that I can't remember. The previous owner, for some reason had cut them. What I did was take a razor blade and make a nice clean cut on the ends. Take a piece of shrink tube and place it on one side of fiber optic. Hold the two cut ends together and slide the shrink tube over the joint. The secret here is to have some one else hold the two sides of fiber optic tightly together while you use a heat gun to shring the shrink tubing but not to much heat. It's not perfect but it worked in the old Caddy for several years before I junked it.
Happy camping and good luck nm1oqrz PS> don't try to use glue!
07-09-2012, 09:55 PM
1971 23' Safari
Cranbrook
, British Columbia
Thanks for the responses. Definitely not a show piece so I guess I won't worry too much. Will try splicing them together.
07-11-2012, 04:35 PM
1967 17' Caravel
Brooklyn Center
I am in the fibre cable business. Maybe I have a leftover that will work. I need a length and a picture of the tip connector...and no, you cannot splice fibre
07-11-2012, 06:25 PM
1972 29' Ambassador
St. Paul
Albertk - remember this is a 1971 Safari - the glass fiber is probably made by hand in a coal-fired forge and only 12 or 37 times thicker than anything used commercially in the last 20 years...
07-11-2012, 06:50 PM
Sunset Beach
Just a thought, but you might check with Andy at Inland RV Center in Corona, CA. I have found him to be very helpful and to take the time to really understand your needs in the past.
Cheers,
Rion
GinMame (Rion & Nobuko DuVall)
AIR# 58703
TAC CA-24
07-11-2012, 06:57 PM
1981 31' Excella II
New Market
, Alabama
I had the same issues and got rid of the system. One of my fibers was broken and I cut the other replacing the rear floor. I also put a plate over the output on the left front corner of the trailer. I think it was a leak point. You could get you a couple LED's and put them where the fibers went. You would need to remove the front skins to access though. Again more trouble than is it worth.
Perry
| Thread Tools |
| Display Modes |
