Old 07-24-2005, 09:28 AM   #1
knjobrien5's Avatar
1969 31' Sovereign
Albuquerque , New Mexico
Polyurethane Foam
Need polyurethane foam or other foam replacement cushins for front couches in 1969 Land Yauht Soverign 31'. We also need curtains. Any ideas?
knjobrien5 is offline   Reply With Quote
Old 07-24-2005, 09:30 AM   #2
RichardT's Avatar
Most fabric stores have Foam in various grades available and can cut it to any size you need.
RichardT is offline   Reply With Quote
Old 07-24-2005, 09:33 AM   #3
jaiman's Avatar
Images: 32
I went to a specialty foam store that is here in Portland. I should let you know they are not cheap. Actually very expensive but they have a great selection of very good quality foams of varying densities and thickness'.
Jai
jaiman is offline   Reply With Quote
Old 07-24-2005, 09:33 AM   #4
Over59's Avatar
Putnam , Connecticut
Images: 37
Don't get the firm, too hard, esp if you use it for a bed. There is as much techical issue's with foam as anything else, firmness, density, ect. If you have a local upholester you may be best using them to make the cushions.
Over59 is offline   Reply With Quote
Old 07-24-2005, 11:05 AM   #5
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Hi Jai, IS that Portland OR ? Just wondering, I need to find some foam. You can PM with the name if it is in Portland, OR.
Chris
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 07-24-2005, 02:19 PM   #6
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Check this out:
www.knoxfoam.com
They can make you slip covers to protect the foam, and have excellent quality. There is also a page that will explain the differences of the different foam types etc.
I have purchased a lot of foam from them over the years, mostly sound barrier sheets, but also mattress foam for my tradewind. Always had a grat experience.
I will buy the foam for my 1963 Overlander project from them as well.
Uwe
www.area63productions.com
Old 07-24-2005, 07:50 PM   #7
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
Can MiracleFoam (Tempurpedic type) be used? AHHHHH Now, that would be a great couch cushion. I think I have seen thicknesses of 3-4 inches available on line.
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 08-14-2005, 07:48 PM   #8
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Also try the Foam Source, in Boulder, CO. I ordered foam cut to within 1/4" of what I needed for another project trailer, in varying densities and depths with no laminating necessary. They were very easy to deal with and they ship for free!
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
expanding foam insulation DinubaDave Exterior Restoration Forum 8 06-30-2005 08:19 AM
Foam Insulation? Aluminum? Loose Curtain Rails? Revamp Goucho? 74Argosy24MH General Interior Topics 4 02-03-2005 08:39 PM
foam under plywood flooring? JeepinAudiophile Repairing/Replacing Floor &/or Frame 3 07-12-2004 08:44 PM
foam cushion replacement mareinmn Upholstery, Blinds, Walls & Interior Finishes 1 03-11-2003 09:21 AM
Twin rear beds DClark General Interior Topics 15 11-24-2002 08:49 PM
