Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 10-04-2009, 08:56 PM   #1
SSChanger's Avatar
Profile:  1994 30' Excella
Huntsville , Alabama
Smile Pocket Door Repair
The rear pocket door on Twinkle, our 94 30' Excella, was easy to open but hard to close. I got that settled this afternoon in the following manner:
1. Removed the top wooden door cover--just two phillips screws and it was easy to take out.
2. Got a small box wrench, and after moving the plastic holder back, raised the rear roller assembly pretty quickly.
3. Gave a good squirt of WD-40 to both rollers, wiping off any excess
4. Replaced the top cover. Works great!
Hope this helps!
SSChanger is offline   Reply With Quote
Old 10-04-2009, 09:21 PM   #2
Airslide's Avatar
Profile:  2001 30' Limited
Novato , California
Images: 47
Send a message via Yahoo to Airslide
Yup.. I had a similar experience but I took mine further. I removed the full plywood wall on the bedroom side to see what it was dragging on. once removed I saw all kinds of little problems with the wood strips that used to be attached places and now just dangled ect.. The door was beginning to separate too making it a bit wider. Oh boy there is just no end to the fun!
Glad yours just took WD-40
Vinnie
2001 Airstream 30' S/O 70th Anniversary
1994 F-350 Crew 7.3 IDI Turbo, C6, Dually
Airslide is online now   Reply With Quote
Old 10-05-2009, 06:29 AM   #3
SSChanger's Avatar
Thumbs up Pocket Door Repair
Thanks for the excellent idea--I didn't think of that. Did you have to remove the cabinet to remove the wall? Bet I've got similar things going on inside the wall too.
Your 2001 30' with the slide out looks great! Bet you enjoy the slide out. has it worked out well for you?
Thanks again for the additional idea!
Dennis
Pocket Door Removal fabu007 Doors & Locks 3 07-26-2009 10:05 PM
Pocket door rollers for 67' Safari Adair Cabinets, Counter Tops & Furnishings 3 10-12-2007 10:23 PM
Pocket door problems 70 anniversary model M Johnson Doors & Locks 0 12-09-2005 08:26 PM
How to tighten loose pocket door? tkoch General Interior Topics 1 09-04-2005 05:50 PM
Pocket Door vs. Accordion (folding) Door A/S Interior pap Cabinets, Counter Tops & Furnishings 12 03-10-2005 05:40 PM
