08-25-2010, 09:58 PM
1978 31' Excella 500
Tuttle
, Oklahoma
Plastic inserts for bathroom trim
I have a 78 Excella that I am working on.
I need to replace the trim inserts in the trim around the tub and along the front of the counter top.
The insert snaps into the metal trim that covers the joint lines of the plastic tub, counter etc in the rear bath model.
Does anyone know where the plastic insert material can be found?
08-25-2010, 10:20 PM
1976 25' Caravanner
North Charleston
, South Carolina
i'm a newbie here but i think what you are looking for is available at out-of-doors mart and called plastic white nose insert. www.odmrv.com
08-25-2010, 10:37 PM
Tuttle
, Oklahoma
Hey thanks Starscream!
I'll have to measure but that looks like what I need.
Darrell
08-25-2010, 11:31 PM
1976 25' Caravanner
North Charleston
, South Carolina
no problem. glad i could help.
tara
08-27-2010, 12:55 AM
ohio
, Ohio
hi
When you replace the tub with counter top it gives a new look to your bathroom. There are many supplier available in the market for plastic material with good quality which can give great look to bathroom.
04-25-2011, 06:26 AM
2005 19' Safari
2005 19' Safari
new iberia
, Louisiana
plastic nose insert
Make sure you measure,I order it from out of door mart and it won't go in,it started off good but then stop.I was putting it in the front on a 77 overlander.
04-25-2011, 07:06 AM
Corona
The insert must be trimmed so that it can slide in the molding.
Airstream enlarged it many years ago, for a different molding.
We have ours down, before it is ever shipped.
04-25-2011, 07:11 AM
1974 Argosy 26
Morrill
, Nebraska
Trim
If yours is like mine; the strip is 1 1/16" wide. Most of what you will find is only an inch wide. After searching the web, I decided to try to make my own. I cut strips from the same vinyl (sheet) flooring. The vinyl is easily cut with a pair of scissors. I've attached a pic.
04-27-2011, 07:40 AM
1976 Argosy 24
Joplin
, Missouri
This was my solution for this problem:
# 20
Isadora
Profile: 1976 Argosy 24
Joplin , Missouri Posts: 2,622
I replaced my insert nosing with vertical blind material, comes in 16 ft stips for about $3 a strip, cut it into 1" wide strips and slipped it into the aluminum channel. It comes in about a hundred colors. I did the whole trailer for less than $10.
Jim and Sandy
"To know is nothing at all. To imagine, is everything." --Albert Einstein
Welcome to Chaos
03-09-2017, 03:27 PM
2012 25' Flying Cloud
Cumming
, Georgia
Where did you get your blind slats?
03-09-2017, 05:51 PM
1977 27' Overlander
1996 34' Excella
Florida Panhandle
We made do with what we had around the house and used it throughout the whole camper and it's been going on strong for 3 years now. . Washi Tape. Less than $30 and we can switch the colors up anytime we want! Certainly not for everyone.
The Evans' Family
Florida Panhandle
1977 Overlander / 27' ~ The Attitude Adjuster
1997 Airstream Excella / 34' ~ The Sane Asylum
