Old 05-17-2011, 04:10 PM   #1
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Pink insulation
Dose anybody have a source for the correct thickness of pink fiberglass insulation or do I have to strip the 3.5 inch bats to fit in the walls.I tried it and the results were not that good
shepherd57 is offline   Reply With Quote
Old 05-18-2011, 07:22 AM   #2
shepherd57's Avatar
Lindsay , Ontario
Anybody there
Old 05-18-2011, 08:34 AM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I split the 3.5" bats in half on my Liner rebuild.
Bill
Just my personal opinion
Old 05-18-2011, 08:40 AM   #4
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
I am contemplating goin with polystyrene instead...
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 05-18-2011, 08:46 AM   #5
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
insulation
Here we go again.....
ddstech is offline   Reply With Quote
Old 05-18-2011, 08:47 AM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
You can buy unfaced fiberglass insulation from a variety of sources. I have purchased it from Home Depot in the past. As far as the width you will probably have to split your own.
Aaron
WBCCI #XXXX AIR #2495
Old 05-18-2011, 11:51 AM   #7
shepherd57's Avatar
Lindsay , Ontario
Thanks for the reply's that is what I thought. I was just hoping there might be a source.
Old 05-21-2011, 11:18 AM   #8
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
I was perusing the aisles of one of our local "big box" home improvement stores yesterday and found that they had 2" foil faced fiber-glass insulation labeled for use as pipe wrap in 16" wide rolls...that might help.
Old 05-21-2011, 11:42 AM   #9
Images: 59
I used split 3 1/2" batts. I think you just need to try a few more to get used to the splitting technique. It wasn't too hard once I got into it.
Wear gloves and sleeves.
Old 05-21-2011, 02:20 PM   #10
cosmos's Avatar
1965 17' Caravel
Birmingham , Alabama
Images: 8
Yes, just split the 3 1/2 thick batts. Use the longest pair of scissors you can find and just go for it. You get twice as many pieces for your trouble. Resist the urge to stuff the 3 1/2 thick piece in there, it won't insulate as good as a thin, uncompressed piece. Do yourself a favor and look for formaldehyde free insulation. I think JM makes it. Then after you quit for the day, scrape your skin down with the edge of a sharp credit card to get all those glass fibers off. You'll itch less if you do.
Cheers
Bill
cosmos is offline   Reply With Quote
Wall Material & Insulation tr0y Upholstery, Blinds, Walls & Interior Finishes 0 03-20-2011 09:52 AM
Fiberglass vs Cotton Insulation GeocamperAS General Interior Topics 13 03-09-2011 07:22 AM
Insulation lmassa Belly Pans & Banana Wraps 4 02-24-2011 10:17 PM
Insulation CampUnger General Interior Topics 3 02-13-2011 07:52 PM
Frozen jug of pink stuff Jammer Winterizing, Storage, Carports & Covers 7 02-08-2011 11:56 AM
