Old 05-10-2015, 08:25 PM   #1
1968 20' Globetrotter
Centenial , Colorado
Partial ceiling cut out for wiring?
I promise I've searched the forums before asking this!!!
I have a '68 globetrotter that is now in our new corporate HQ. It will be used daily for meetings and interviewing new prospects.
I've had it buffed out professionally. I've started stripping the Zolatone on the front and back below the end caps.(thanks for the link to Citrastrip!)
I need to rewire it as code inspectors wont approve the good but not professional job the last owner did. I only need overhead lights and probably three duplexes as well as getting the running lights operational.
I have a few rolls of 2024 T3 that I will put over the existing interior panels. I am thinking if I bring the power along the exterior roof and drop into the old A/C cut out then I can just saw out parts of the existing ceiling panels to run the new wiring. I can put in the new ceiling LED's and then put the new Alclad up.
Thoughts?
Kingofbanff is offline   Reply With Quote
Old 05-10-2015, 08:31 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My Bambi II did not originally have an Air Conditioner. Previous owner had one installed. At least three inside panels were partially removed to run the water and drain line.
MICHAEL
Old 05-10-2015, 10:15 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The wiring harness should be in the ceiling down the mid line of the trailer
Old 05-10-2015, 10:22 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If looking to run additional wiring, just use some aluminum channel down the center inside. Or make a c channel out of wood to "hide" wiring then screw to the ceiling. You won't be moving it so it need not be structurally secure.
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-10-2015, 10:26 PM   #5
My trailer seems to have two aluminum panels meeting in the centerline of the ceiling. Elsewhere on this forum it seemed as though some trailers have a two or 3 foot wide ceiling panel that can be taken out.
Do you think I can remove the centerline ceiling trim and then just peel the left and right side panels back a few rivets to access the harness?
Air Conditioner for '74 Argosy? Cut the ceiling? Eaglemate Furnaces, Heaters, Fireplaces & Air Conditioning 10 08-27-2013 04:25 AM
1965 Safari hitch wiring cut off ElaineH Towing, Tow Vehicles & Hitches 6 10-06-2012 05:47 PM
Ceiling lights not working-wires cut- where do they go? idaramin Lights - Interior & Exterior 2 09-13-2012 09:21 AM
Nail in water line: Need to cut out floor & patch AirHeadsRus Repairing/Replacing Floor &/or Frame 12 07-17-2009 05:56 PM
AC hole cut-out framing silver 67 Furnaces, Heaters, Fireplaces & Air Conditioning 8 10-05-2006 10:53 AM
