Old 02-28-2016, 04:30 PM   #1
1972 31' Sovereign
Jasper , Indiana
Painting the inside walls
Have a 31ft 1972 Sovereign. Have cleaned walls but still areas that just won't come clean. Has anyone painted the walls before and if so what did you use.
Thank you
Bramlett1974 is offline   Reply With Quote
Old 02-28-2016, 06:00 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
You will get recommendations to use KRYLON FUSION spray paint, lots of people have had good results with this.
I wouldn't have the patience for this, especially on a 31 footer.
I would really, really, really clean the surface with a cleaner like PREP SOL, sand the surface to get some tooth and paint with a good oil base enamel like RUSTOLEUM or similar,,, or even better, INDUSTRIAL IMRON HG-3500.
A high quality paint will "lay down" smooth after rolling or brushing, and if applied to a clean well prepared surface, it will stay for a very long time.
A straight enamel like Rustolium will out gas for a few weeks and smell of solvent for a while, the Imron will fully cure odor free in a few days.
I would not use any kind of latex or common house paint.
By the way, we also have a 72 Sovereign...
Talis gentium ceciderunt.
Old 02-28-2016, 08:45 PM   #3
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Hey Bram
After filling holes and light sanding, I then used an oil base stain blocking primer and a latex overcoat. Had good results.
Tim
Beaker63 is offline   Reply With Quote
Old 02-28-2016, 08:48 PM   #4
andreasduess's Avatar
1984 34' International
Toronto , Ontario
This is excellent advice.
andreasduess is offline   Reply With Quote
Old 02-29-2016, 10:22 AM   #5
1973 Argosy 26
dawsonville , Georgia
After filling the holes and sanding, I used a standard interior matte finish paint and it looks great. I used the Krylon Fusion on the plastic features and also had really good results.
Also, may want to invest in a couple of cases of MagicEraser.
Cleosdad is offline   Reply With Quote
Old 02-29-2016, 10:58 AM   #6
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
My wife lightly sanded and used a good latex on our walls (1970 safari) .... it worked great and has held up fine after 2 years. She rolled it on and didn't seem to have any issues at all.
rucos is offline   Reply With Quote
Old 02-29-2016, 11:06 AM   #7
Satellite Beach , Florida
We are in the process of our interior restoration of our 1979 Sovereign. So far we have used Krylon Fusion on all of the upper tambour cabinets and endcaps with excellent results, although it took 4 thin coats and countless cans. We have done test patches successfully of BIN primer after cleaning twice, sanding, and the final cleaning with a mild ammonia solution, which is what we intend to use for the rest of the trailer. Haven't made a final decision on what type of paint to finish with, but many say that a regular interior latex is fine over the BIN, and that's what we're leaning towards. Good luck!
suzuz22 is offline   Reply With Quote
Old 02-29-2016, 04:53 PM   #8
1971 27' Overlander
zeeland , Michigan
I think it's been post here that 71 and later Airstreams used a vinyl coating on the interior. Has anybody here ever used Benjamin Moore Revive for vinyl siding. The sales person at the paint store thought this would be a great choice, but he never did it.
binnendyk is offline   Reply With Quote
Old 03-01-2016, 06:25 AM   #9
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
3 coats of Kilz II, then rolled on Zolatone FLEX. Easy application, looks great, super strong... not inexpensive!
SuzyHomemakr is offline   Reply With Quote
Old 03-01-2016, 07:07 AM   #10
1964 24' Tradewind
Lawrence , Kansas
Hi SuzyHomemakr. Have you got any photos? How rough is the texture? Did you have everything out? How was the texture where you had to "cut in" instead of rolling?
thanks
ttbikes is offline   Reply With Quote
Old 03-02-2016, 05:43 AM   #11
1971 31' Excella 500
santa rosa , California
I have close to the same year and model. I had doubts but I painted anyway, and it turned out killer. I used a Kelly Moore glossy latex. Be brave my fellow fuselage dweller!
lornahanen is offline   Reply With Quote
Old 03-02-2016, 06:16 AM   #12
1972 29' Ambassador
thanks
I would say the texture is rougher than regular paint, but smoother than sand paint. It hides a lot of sins! Contact your local Zolatone dealer, and ask for sample chips.
You can paint a bit at a time, it doesn't seam from old to new. I used a chip brush to stipple in the edges, sort of jamming it straight in. The product is applied in two stages, first a base coat (which they call "primer"), then the multi-color coat with the funny roller.
They custom blend every batch, so be sure to order enough for the entire job. I wound up not doing the center stripe on the ceiling, and also left the bathroom white. I had a lot left over. That stuff is expensive!
Name:	2015-02-19 16.52.44.jpg
Old 03-02-2016, 07:42 AM   #13
1964 24' Tradewind
Lawrence , Kansas
Thanks for the response! I was most concerned about the transition from the cut in to the roller. So I am really glad to hear the seams did not show. Even more glad to hear they did not show when going from dry to wet.
What color did you use? The wife says that is the one she wants. I have ordered paint chips.
Old 03-03-2016, 05:32 AM   #14
1972 29' Ambassador
I used FLX-0017, sort of a sand color. The flecks are kinda subtle, I was actually hoping for something a bit bigger. Through its formulation and colors, it really smooths out gouges and scratches. I wish that I'd used some of that Big Stretch caulk on the seams, as that's where I've had some cracking from the trailer flexing.
Painting Walls of Bambi Marshall44 Upholstery, Blinds, Walls & Interior Finishes 13 04-19-2010 01:25 PM
Painting 1984 Excella Walls Aluminumb 1984 -1986 Excella 5 10-22-2007 07:51 AM
Thoughts on painting oak cabinets & walls potatoes Cabinets, Counter Tops & Furnishings 17 01-16-2006 10:56 AM
Painting Interior walls, Ceiling DJbyRequest General Interior Topics 37 05-29-2005 09:51 PM
Painting plastic walls and bathroom sink jwaldin Upholstery, Blinds, Walls & Interior Finishes 4 11-14-2003 08:37 AM
