Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 12-19-2004, 05:24 AM   #1
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Painting Bathroom fixtures
I have to share this! We found a product that covers so well it is almost unbelievable! The bathroom plastic has taken some UV damage over the years, Chalking and discoloring. I had to remove everything to get at a problem on the floor. This made it a great time to go after refinishing. We searched the internet and found POR 15 products.
WHITECOTE™ the toughest, most beautiful white coating you'll ever use. Like our internationally-famous POR-15®, WHITECOTE™ cures to a rock-hard, non-porous finish that won't chip, crack, or peel when applied as directed. It's perfect for wrought iron patio furniture, plumbing fixtures, etc., because it's super-tough, not UV-sensitive, and brilliantly white. Use it to repair a bathtub or sink with chips or rust stains, or to paint and protect an old boat, trailer or RV, or anything that you want to be permanently white
http://www.por15.com/product.asp?productid=233
balrgn is offline   Reply With Quote
Old 12-19-2004, 05:40 AM   #2
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
Savannah , Missouri
Send a message via ICQ to 53flyingcloud Send a message via Yahoo to 53flyingcloud
Thumbs up Thanks~!!
balrgn,
Thanks for the tip~
The finished results look awesome~!
Now if I could just get my 64GT over to your driveway....
Seriously, I need to pick your brains for a minute about getting behind the sink..
And, about the work you've been doing on your tractor~!
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 12-19-2004, 05:54 AM   #3
balrgn's Avatar
Images: 74
Cool Paint
Thanks, getting behind the sink area seems much harder than it really is. I'd be glad to share anything you need to know. We'll have to get together soon!
I just checked on the curing of the paint. Take quite a while, 48 to 96 hours. I have my shop @ 65º. The stuff is setting up like porcelain!
Old 12-19-2004, 08:04 AM   #4
Happycampers's Avatar
Profile:  1979 30' Argosy
Peterborough , winter home Zavalla TX
Talking Pics please
Good Morning, We would love to see some pics of your bathroom. Have used the Por 15 on the frame of our Argosy. If this product is as good , might be ordering some. Annie and Marvin
Marvin & Annie
Toby & Niki (fur babies)
1979 Argosy 30 (Costalotta)
WBCCI 10103
2005 F250 Lariat Power Stroke Diesel Crew Cab 2wd
Yamaha 3000
"Happiness is a warm Puppy" Charles Schulz
Happycampers is online now   Reply With Quote
Old 12-19-2004, 08:24 AM   #5
Savannah , Missouri
Good Idea
I couldn't agree more~!
I'm off to another location..(work)
Will reply to pm soonest..
Thanks for the tip..
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 12-19-2004, 08:21 AM   #6
Ken J's Avatar
Profile:  1958 26' Overlander
Tijeras , New Mexico
I think rustoleum makes a similar product called tub and tile -
Did you use this on your porcelain sinks or just fiberglass? I need to find something for the porcelain sinks of my 58....
Ken
1958 Overlander
Ken J is offline   Reply With Quote
Old 12-19-2004, 12:08 PM   #7
balrgn's Avatar
Images: 74
Cool
This product is UV and moisture resistant, It is made to resurface bathroom fixtures, I used it on the plastic in my '75. I've heard of it used on a porcelain tub and worked great. (Moisture makes it cure faster so be aware!)
I have some pics on my web page, I'll be posting more as we go.
Old 12-21-2004, 03:11 PM   #8
balrgn's Avatar
Images: 74
Cool Paint
I wanted to post an update. It has been a little over 72 hours since we applied the paint. It has been curing slowly just as described in the data sheet. I left it in the work shop for 36 hours @ 35% humidity. As it happens the gas furnace out there reduces the humidity. it was a huge benefit for this. After 1/2 through the cure I took the 3 painted pieces inside where the humidity is around 50% this helped the curing. It is now extremely hard but the pieces are very pliable. 24 more hours and it reach the optimum cure. So far I am delighted with the way the pieces came out!
Old 12-21-2004, 09:31 PM   #9
RiskIt's Avatar
Profile:  1972 25' Tradewind
Lake Worth , Florida
Send a message via AIM to RiskIt Send a message via Yahoo to RiskIt
I used a two part epoxy and sprayed it...... took over a week to fully cure. But you know how cold it's been up here. First day you could pick it with your finger nail, tonight (1 week) was walking on the shower pan with muddy/snow/wet boot's - looks like new. Major difference......
RiskIt is offline   Reply With Quote
Old 04-16-2006, 12:12 AM   #10
Angel73's Avatar
Profile:  1975 31' Sovereign
Woodlawn , Tennessee
Images: 65
Send a message via Yahoo to Angel73
I have some cracks in the shower where you sit.I was wondering if there anyway to repair this or should we just replace it.We don't use the bathroom at all but for storage so we never noticed it before now.After seeing your post about the whitecote We was going to try it on the bathroom sink since the sun had discolored it.then we found the two cracks in the shower sit.So i wanted to see what you'll had to say first.
Angel73 is offline   Reply With Quote
Old 04-16-2006, 12:31 AM   #11
GreatPumpkin's Avatar
Profile:  Currently Looking...
Colville , Washington
Images: 70
Looking for a product to redo the sink in my AS. It is the original WHITE double bowl. We want to make it BLACK. OUr new countertops are going to be a blakc granite pattern laminate. The only product I've found readily available is Tough As Tiles, but it is only available in WHITE or tintable with a max of 1 ounce.
Either that or a good source for a small BLACK sink, doesn't have to be double bowl, could be single. If I can't refinish the existing, or find a BLACK one to fit, I'm stuck going with Stainless Steel, which I'd prefer not to do.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 04-16-2006, 05:58 AM   #12
balrgn's Avatar
Images: 74
I had a crack in the seat of the shower as well, Por 15 (sounds like an edorsment) has a 2 part epoxy that looks like sticks of putty.
http://www.por15.com/PRODUCTS/PUTTYF...7/Default.aspx
It worked great, made a ball, that looked like silly putty and spread it out over the back side. Place a thin layer on the front side and smothed it out, let it dry, hand sanded it. You can not even see it was there now.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
Old 12-21-2004, 10:09 PM   #13
Ken J's Avatar
How does the finish come out if you brush it rather than spray it?
Ken
1958 Overlander
Old 12-22-2004, 05:01 AM   #14
balrgn's Avatar
Images: 74
Cool Paint
Ken
They claim it it comes out the same or better brushed. I prefer spray. It goes on in an even 2" path, holding the gun 6" - 8" abobe the piece. You need a pretty large dia. tip to spray. You MUST put 2 coats. If you want it to level rigtht.
You can see the pics on my website below.
Blower in bathroom? uwe 1970-79 Tradewind 14 03-07-2008 10:40 PM
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 09:01 AM
Bathroom Mirror niftypkg General Interior Topics 4 09-03-2002 06:38 PM
Painting your Airstream jkleven Clearcoat, Exterior Paint & Trim 25 07-18-2002 04:32 PM
Bathroom Counter Trim 74Sovereign Upholstery, Blinds, Walls & Interior Finishes 1 07-10-2002 07:36 AM
