Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 09-21-2009, 01:30 PM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Painting Plastic End Caps
I'm sure someone on the forum has experience with painting the plastic end caps. Do you care to share your experience and how the paint is holding up. What did you use to paint the end caps. Thanks for your help!
Roadrunner is offline   Reply With Quote
Old 09-21-2009, 03:29 PM   #2
Over59's Avatar
Putnam , Connecticut
Images: 37
First issue is know what material they are made from. My 59 was fiberglass. I would do them in place unless you are taking them out for some other reason. They are very hard to get back in.
I used a two part product from Por-15 that worked great. There is spray paint out there for plastic also. As always with painting it's all in the prep.
Over59 is offline   Reply With Quote
Old 09-21-2009, 03:44 PM   #3
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
I painted both the front and rear inside end caps with flat latex paint that I had mixed at Shewin Williams. They had turned an ugly yellow over time. I took a piece of trim with the original light tan color of the ceiling and walls and they matched perfectly. I got a quart of the flat and a quart of the semi-gloss enamel and have used both in various places inside the trailer. Clean the caps with water and a cloth and sand any rough places. If you have any cracks running form the outside edge ending in the cap itself, drill a small hole (the smallest bit you can find) at the very end of the crack. This will stop in most cases the crack from getting longer. Fill the hole and crack the best you can with a paintable caulking and smooth out. Like I said I used the flat latex but the enamel would probably work as well. They look great and have for almost 10 years. You can certainly use a more elaborate coating/paint but the latex seems to do the job. I can awys touch it up if I need to.
Don
adonh is offline   Reply With Quote
Old 09-21-2009, 04:22 PM   #4
LJH
LJH's Avatar
1985 27' Sovereign
Defiance , Ohio
I super cleaned them, then did a coat of Kilz then two coats of latex. Seems OK so far.
LJH is offline   Reply With Quote
Old 09-21-2009, 04:28 PM   #5
gutsgolf's Avatar
1972 31' Sovereign
Hattiesburg , Ms
Send a message via AIM to gutsgolf Send a message via Skype™ to gutsgolf
I had to admit ignorance but i keep seeing por 15 mentioned. What is it and why so important to use it
Richard & Marika
31' International
Land Yatch
"Silver Belle"
AS 16741
gutsgolf is offline   Reply With Quote
Old 09-21-2009, 06:21 PM   #6
georgezink's Avatar
1977 Argosy Minuet 6.0 Metre
Cape Coral , Florida
Images: 34
Ditto to Don's comments on treating cracks prior to painting...
On our '77 Minuet, the interior endcaps are ABS...
They were both thoroughly cleaned with Simple Green and rinsed well. The fore endcap was primed with Zinsser BullsEye latex primer and top-coated with Varspar satin interior latex in a neutral off white. The aft endcap was spray painted with Krylon Fusion due to the fact that it would be subject to water overspray from the aft shower. When we did the Krylon Fusion, the rest of the coach was practically gutted - so we were able to keep the area well ventilated without worrying about the spray mist settling on other surfaces. We would have looked at other options had everything still been in the coach - or done a complete job of covering it all...
This paint has been down for over two years now, with about 5,000 miles of traveling. It's held up very well with no cracking, peeling, or chipping - or need for a touchup...
George
flcracker
georgezink is offline   Reply With Quote
Old 09-21-2009, 06:35 PM   #7
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
These are great tips! I've heard others that really went all out with the cleaning, priming, and special paints; only to end up having problems.
It's good to know that good old standard primer and latex holds up well.
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
https://www.airforums.com/forums/blog...-maryw164.html
https://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 09-21-2009, 07:29 PM   #8
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Thanks for all the replies. The great thing about the forum is the amount of information you can get from others experience. Looks like we'll be sanding, priming, and painting...now if we could figure out what to do with the vinyl covering on the ceiling...
Old 09-21-2009, 07:49 PM   #9
Kevin245's Avatar
POR 15 is a rust inhibitive coating that is very tough. It is a polyurethane that is moisture cured, and can be applied over rust. POR also sells coatings for other applications as well.
POR-15 is used by many forum members for frame coating.
www.por15.com
Regards,
Kevin
William C. Swinney
Old 09-21-2009, 09:23 PM   #10
Over59's Avatar
Images: 37
I used this for the end caps and to recoat the tub. Look like new enamel coating. They have an other top coat produce that comes in colors.
WHITECOTE-POR-15 Inc.
Old 09-21-2009, 09:49 PM   #11
georgezink's Avatar
Images: 34
For the vinyl - scrub with Simple Green - rinse thoroughly - two coats of Future acrylic wax. Mine's still doing great after two years - no stickys and easy to clean...
George
flcracker
Old 09-21-2009, 10:57 PM   #12
somefun's Avatar
1974 27' Overlander
Puyallup , Washington
Here's what worked for me: http://www.airforums.com/forums/f46/...tml#post228662
It still looks like new, and is probably the refurb that I'm most happy with on my trailer.
P.S. After the paint dried, I used a fine ScotchBrite pad to take off the sheen and give it a "satin" look.
somefun is offline   Reply With Quote
Old 09-22-2009, 10:43 AM   #13
Maryw164's Avatar
1972 31' Sovereign
This is a good thread to read also about others painting trials and tribulations. Lots of good helpful info.
http://www.airforums.com/forums/f39/...cky-55249.html
Mary
Happy Trailering !
plastic goucho end caps twinke74 General Interior Topics 0 08-13-2009 09:54 PM
Curtain Valance End Caps & Gaucho Rail Plastic #201295 KAYAKAMPERS All Argosy Trailers 13 02-13-2009 06:27 AM
Cracks in end caps? Anniedog General Interior Topics 8 05-30-2008 09:00 PM
interior plastic end caps catson4 Interior Restoration Forum 1 01-05-2008 06:30 AM
plastic end caps for horizontal blinds bpcaudill Upholstery, Blinds, Walls & Interior Finishes 6 09-26-2006 07:44 PM
