Old 07-15-2004, 11:01 AM   #1
Gary & Lurleen
Painting Interior walls, Ceiling
Has anyone had any luck or experience (good or bad) painting their interior. I have a 1988 excella 32. The ceiling and walls are beige/mottled brown, and the plastic panels above the sofa/ rear twins is yellowed. My wife has watched too many trading spaces episodes and wants to paint the walls and celing pink (don't ask). I am concerned about the paint not sticking, especially to the plastic parts. Help!!!
DJbyRequest is offline   Reply With Quote
Old 07-15-2004, 11:24 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
If it's first clean very well with TSP or something similar, rinsed well, then primed with Kilz or some other product meant to go over vinyl wallcovering (brown mottled) & plastic, it'll be fine.
Sorry...can't help you with the pink, maybe you ought to get rid of your cable channels!
Shari
Old 07-15-2004, 11:47 AM   #3
Lee Pace's Avatar
We painted our bedroom in our 69 with semi-gloss and it is very smooth and looks great. It is an improvement we would make again. The good thing about the semi-gloss is that we can wash it and it always looks good.
Don Pace
69 Overlander
WBCCI 7287
Lee Pace is offline   Reply With Quote
Old 07-15-2004, 02:34 PM   #4
The Sh*tt*r's Full!
dbtolman's Avatar
1970 27' Overlander
lewisville , Texas
Don Pace
69 Overlander
WBCCI 7287
Did you prime first, or make any preparations?
What brand and type of paint did you use?
How did you apply the paint?
I'm considering doing the entire interior on my 72 Overlander International.
Thanks!
dbtolman is offline   Reply With Quote
Old 07-15-2004, 04:37 PM   #5
Somewhere in the archives is a thread on painting the plastic end caps. You will need a paint, or at least a primer that adhears to abs plastic. I used a spray plastic primer - probably Krylon, I don't remember, and then just regular spray paint. However, I have painted other abs items (notably the inside a/c cover) with Krylon Fusion - no primer - and it has worked really well.
Mark
Old 07-15-2004, 04:43 PM   #6
dbtolman.
Painting the interior is not difficult, but there is a game plan that "must" be followed.
First, clean the wall material (vinylclad).
Next, cut into the vinyclad with 120 to 150 grit sandpaper. Don't scuff it, but cut into it.
Next, apply a good grade flexible primer.
After the primer ages for a few days, you may now use most any "high" quality paint.
If you do not follow the above, the paint will eventually peel, especially if your in a "hot" climate.
Old 07-15-2004, 04:55 PM   #7
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
I am sorry to be the barer of bad news, but even with all the great suggestions given, PINK paint will not adhere to any interior surfaces in your Airstream.
Break it to her gently.
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 07-16-2004, 11:15 PM   #8
The Sh*tt*r's Full!
dbtolman's Avatar
1970 27' Overlander
lewisville , Texas
dbtolman.
Painting the interior is not difficult, but there is a game plan that "must" br followed.
Thanks!
When you say any high quality paint, are you speaking of a rolled on house paint, or spray paint?
Thanks!
Old 07-17-2004, 09:59 AM   #9
Either one, but it must be near the top shelves, not the bottom ones.
Old 07-17-2004, 10:02 AM   #10
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Does the same apply for older zolotone surfaces?
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 07-17-2004, 10:08 AM   #11
Ken.
Absolutely.
Or you can spray the old Zolotone with some new.
It's still tough as steel.
Old 07-18-2004, 09:11 PM   #12
The Sh*tt*r's Full!
dbtolman's Avatar
1970 27' Overlander
lewisville , Texas
Andy,
Not sure what you mean about near the top, not the bottom?
Thanks!
Old 07-19-2004, 08:06 AM   #13
dbtolman.
Paint is like booze.
The higher on the shelf, the better it is.
The lower on the shelf, rot gut, not good unless you don't care.
Old 07-19-2004, 08:25 AM   #14
Lee Pace's Avatar
Interior Painting
We cleaned the walls with hot soapy water, then dried them. We put on two coats of Behr Semi-gloss.
Good luck,
Don Pace
69 Overlander
WBCCI 7287
Thanks!
Painting Walls of Bambi Marshall44 Upholstery, Blinds, Walls & Interior Finishes 13 04-19-2010 01:25 PM
Painting the Exterior of an A/S Navigator Clearcoat, Exterior Paint & Trim 25 08-06-2004 08:16 AM
Ceiling ripple in rear mmeburges1 General Interior Topics 1 01-11-2004 01:18 PM
Painting? turbocharger All Argosy Trailers 12 01-05-2004 08:33 AM
ceiling liner silverbullet96 General Interior Topics 13 11-28-2003 12:39 PM
