Old 07-19-2004, 09:47 PM   #15
The Sh*tt*r's Full!
dbtolman's Avatar
1970 27' Overlander
lewisville , Texas
dbtolman.
Paint is like booze.
The higher on the shelf, the better it is.
The lower on the shelf, rot gut, not good unless you don't care.
OH!! You mean to make sure I don't buy the cheap ****. Right?
Hmmm.... Well, when it comes to booze, I buy the good stuff... SO, How much for the Zolotone?
dbtolman is offline   Reply With Quote
Old 07-19-2004, 09:50 PM   #16
The Sh*tt*r's Full!
dbtolman's Avatar
1970 27' Overlander
lewisville , Texas
Got pics?
Originally Posted by Don Pace
We cleaned the walls with hot soapy water, then dried them. We put on two coats of Behr Semi-gloss.
Good luck,
Don Pace
69 Overlander
WBCCI 7287
Got any pics of the finished product? The wife might want to see what it looks like before I do it. hehe...
Old 07-21-2004, 10:02 AM   #17
Zolotone prices depend on the color.
A gallon can run from about $100.00 to over $125.00.
Old 07-21-2004, 10:09 AM   #18
Over59's Avatar
Putnam , Connecticut
Images: 37
Does the Zolotone have to be sprayed on or is it just best to do so? They have some really cool finishes.
Over59 is offline   Reply With Quote
Old 07-21-2004, 10:35 AM   #19
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
It has to be sprayed on....that's what creates the 'splattered' look...
The original Zolatone used by Airstream is the solvent based...but the acrylic based are easier for the lay-person to work with.
Water Based - Zolatone Application Spec
Solvent Based - Zolatone Application Spec
Shari
Old 07-21-2004, 02:14 PM   #20
The Sh*tt*r's Full!
dbtolman's Avatar
1970 27' Overlander
lewisville , Texas
YIKES! Suddenly, a nice can of Behr semi-gloss off-white is sounding rather nice.
Old 07-21-2004, 02:36 PM   #21
But "if" you want it to look "right' you have to pay the price, sooner, or later.
With the sooner, it's done.
With the later, you will do it over again, because it didn't hold up.
House paint is for houses. They don't get 140 to 150 degrees, or more, on the inside, like an Airstream can, and does.
Old 10-17-2004, 06:27 PM   #22
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
Question, Andy...
So Andy, are you saying Zolatone is a better choice than house paint? If so I'd pay the money for a couple of gallons.
I was having illusions of the interior aluminum like Tin Can Luv did but with the amount of work ahead and wanting to use the thing sooner rather than later, I'm thinking spraying on Zolatone again would be a better idea. I also looked at the website and decided it would look good after all, and be less maintenance than aluminum veneer.
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 10-17-2004, 07:37 PM   #23
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Zolatone has proven itself far better than any water based paint. I found that out myself as I began stripping the paint on my interior - the water based paint comes right off, Zolatone stays put. In the alternative, you can use a good quality automotive type paint - thats what zolatone - and then they add those "balloons" that give the speckeled look when sprayed. Let me know what you decide to do and how it works out - I'll be painting in the spring.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 10-18-2004, 12:59 AM   #24
1967 24' Tradewind
Images: 38
hello
Ken
Thanks, I had a feeling. We are probably not going to do the aluminum veneer, so we're going to probably paint for sure, and since it's gutted now, we want to paint it ONCE and never have to again, and not have problems with it coming off. No appliance pullouts to repaint. I hated the zolatone at first when I saw it, but given the labor intensive other options, and after seeing the stuff when it's freshly put on, I think we're going to do it. I won't make shortcuts, I like to do it right, so Zolatone it is if it's that durable.
Let me know also how your painting goes. Or just post so I can view it, I'm reading Uwe's and your threads as you go and you both have been really a big help.
I finally took off part of the belly pan and one side of banana wrap, also removed the plastic stuff on the wheel wells, I'm not sure if the PO had that stuff on it or if it was original to the AS. But I'm so proud of myself! I put pictures on my website.
Next I'm removing all the stuff on the inside, taking off the rest of the belly pan, and getting ready for putting in a new floor with Uwe's guidance. It'll be a shell-on replacement (I HOPE!)
Thanks KenJ,
i.
~ Hurley
ingrid
Old 10-18-2004, 06:30 AM   #25
Lee Pace's Avatar
Interior Painting
It has been three years since we painted the walls in our trailer. We live in Texas and our trailer is in the heat in the summer. The semi-gloss paint looks as fresh today as the day we put it on.
We will send pictures. Hopefully this paint will look this good for the next three years.
Good luck,
Don Pace
69 Overlander
WBCCI 7387
Lee Pace is offline   Reply With Quote
Old 10-18-2004, 10:19 AM   #26
Ken J's Avatar
Durango , Colorado
Images: 14
To better clarify what I said - water based paint is being used a lot very successfully. It is not as durable as Zolatone - I suspect water based paint will have to be updated after period of time - which is probably not a big deal, whereas Zolatone can last 40+ years if its taken care of. My 59 Traveler had its original zolatone paint that was in perfect condition. I've seen many old trailers with zolatone in great condition. I also know that come have used rustolem with great results. I would think that fits in somewhere between Zolatone and water based paints.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 10-18-2004, 11:31 AM   #27
Cedars's Avatar
1983 31' Excella
Waterloo , Iowa
I'm not into experimenting myself.....
But.
Any of you guys looked at using hammerite paint? See it here:
http://www.masterchem.com/pages/default.aspx?NavID=44
Especially look at the silver gray color...... seems to me it would make a dynamite interior look.... hmmmmmm
Elizabeth in Iowa
The carpeting is gone! The carpeting is gone! Long live the cork floor!
Cedars is offline   Reply With Quote
Old 10-18-2004, 12:20 PM   #28
1967 24' Tradewind
Images: 38
hmmmmm is right! Good to know about that one.
The 40 years comment on the Zolatone is exactly why I want to use it. I want to give this trailer to my daughter to use when she has kids (hopefully), and we plan to really use it heavily when it's done. That's the same reason we're putting POR15 on the frame instead of something cheaper...but there may be parts we can use other brands on, so it's good to know that both options are there.
I'm told when you actually get the trailer closed in and done, i.e. new floor in and shell firmly reattached, doing the inside is actually pretty fun. That's good news to hear...crawling underneath is sweaty and I'd like to be finally putting things *on* instead of ripping them *out*.
Ever forward...
~ Hurley
ingrid
Painting Walls of Bambi Marshall44 Upholstery, Blinds, Walls & Interior Finishes 13 04-19-2010 01:25 PM
Painting the Exterior of an A/S Navigator Clearcoat, Exterior Paint & Trim 25 08-06-2004 08:16 AM
Ceiling ripple in rear mmeburges1 General Interior Topics 1 01-11-2004 01:18 PM
Painting? turbocharger All Argosy Trailers 12 01-05-2004 08:33 AM
ceiling liner silverbullet96 General Interior Topics 13 11-28-2003 12:39 PM
