Does anyone have any tricks on the best way to strip pait from a 61 Sovereign? Some one painted it with some sort of rough texture pait that is peeling. I want to repaint but need to know what is best way to remove and what to repaint with.
What kind of chemical to use to Strip the paint depends on what kind of paint they used. There are a lot of commercial strippers. Some are flammable and others are not friendly to humans. Go to a good paint store. Originally, the interior of your 61 was painted with a speckle paint. The decision you need to make is: whether you want to restore the trailer or customize it to your personal taste.
Is it one color with specks of other colors in it? If so it is zolatone paint and original to the trailer. Usually this paint is extremely durable and if in good condition I would recommend keeping it. If it is not multicolored than it is probably a previous owner's paint job. I had to remove the interior panels anyway so when they were out of the trailer I washed and sanded them to prep them before applying paint. On the door panel I did remove the paint using citristrip but it took 3 coatings to completely strip the paint. I could not imagine stripping the whole trailer but I am sure people have!
__________________ https://1960airstreamtradewind.blogspot.com
Love. You can learn all the math in the 'verse... but you take a boat in the air that you don't love... she'll shake you off just as sure as the turn of the worlds.
I dont think it is the factory paint....peeling way to bad to be.
Looks like i have my work cut out for me. I also have found pictures where people don't paint the inside and have it polished.
