Old 03-25-2008, 12:10 PM   #1
1978 31' Sovereign
Merlin , Oregon
painting....
hello,
I own a 1974 31' sovereign (ignore the 78) and I wanted to paint the front top bubble section. It occured to me that I would probably need a stretchable paint. Do I? If i do which one would you prefer?
I am also painting on top of the vinyl. I wanted to use just latex acrylic paint. I figured that would work fine. agree?
spanky1313 is offline   Reply With Quote
Old 03-25-2008, 03:41 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The liquid plasticizer in the flexible vinyl will bleed into the bond area under the latex and make the adhesion diminish and the paint will come off in large flakes. The vacuum formed ABS bubble sections will be ok if you prime them with the proper primer. Go to a professional paint store around your area and talk to them. There are a variety of big paint companies who offer primer for ABS plastic. It is usually has a solvent carrier.
Old 03-25-2008, 05:18 PM   #3
1978 31' Sovereign
Merlin , Oregon
Thank you. I will do that.
Old 03-25-2008, 05:53 PM   #4
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Mine was cracked and I used a vinyl wall covering from Lowe's to cover it. Has worked well so far, but wasn't easy. I have a friend in Austin, who used the wall covering and then painted over that with latex paint. His is beautiful. I did use extra wallpaper sizing, glue, and also wetted the wall covering to activate the glue backing.
ID:	56968   Click image for larger version
ID:	56970   Click image for larger version
Judy At Home in Oklahoma
juel is offline   Reply With Quote
Please tell me how to go about painting suze9234 All Argosy Trailers 3 05-23-2006 10:29 AM
Painting the Exterior of an A/S Navigator Clearcoat, Exterior Paint & Trim 25 08-06-2004 08:16 AM
Painting Airstreams Tarheel Clearcoat, Exterior Paint & Trim 2 03-07-2004 08:27 AM
Painting? turbocharger All Argosy Trailers 12 01-05-2004 08:33 AM
Un-Painting an Airstream swebster Cleaning, Stripping & Polishing 4 06-18-2003 05:24 PM
