Old 02-04-2010, 01:49 PM   #15
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
squeaky clean
Now, if you have it squeaky clean, use liquid Future Floor wax, on the walls to seal the Zolatone, if you have that on your walls. This lasts for a few years if you do it, and makes wiping them down once in awhile a snap to do. If they get sticky again it is time to scrub and clean again. Sounds like you are making progress.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 02-04-2010, 04:05 PM   #16
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
NO Simple Green
at least not on bare aluminum - it etches the surface. You'll end up having to polish it all over. On paint, clearcoated aluminum, etc. it's fine.
Paula
Old 02-04-2010, 07:06 PM   #17
tallytwo1994's Avatar
tallahassee , Florida
You'll never totally get rid of the smell unless you remove the layers of nicotine from the walls... On a 1972 trailer you should have no problem either using clear ammonia diluted with a sufficient amount of water or white vinegar and water. The ammonia will work quicker. Use a spray bottle and let it work a few seconds before wiping it off with a soft cloth (don’t spray it in your eyes). Be sure to rinse afterwards with clean water, and rinse again. Then open all windows and door and let it air out real good for several days. Actually before using any chemicals - open the windows and door.
Carol
tallytwo1994 is offline   Reply With Quote
Old 02-04-2010, 08:08 PM   #18
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
... the best SG to use on aluminum.
Aircraft Cleaning – Is Simple Green® safe for cleaning aircraft?
Simple Green manufactures products specifically designed for use on aircraft. Products available on the market are Extreme Simple Green® Aircraft & Precision Cleaner and Simple Green® Pro HD. These products were initially developed for the aircraft industry and extensive testing shows that they are safe for use on aluminum, plastics, rubbers and high tech alloys, even in the most extreme circumstances. These products conform to both Boeing D6-17487P spec for general aircraft exterior cleaning and Pratt & Whitney PWA 36604revC spec for aircraft engine cleaning.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 02-04-2010, 09:44 PM   #19
2008 16' Safari
Destrehan , Louisiana
OK, I'm a smoker. But NEVER in the house and NEVER in the AS. Our first AS was from a couple that smoked a lot in the AS. It was nasty.
We spent 4 days cleaning every surface in the camper. (that's inside the kitchen drawers too)
Simple green, Castrol Purple or any other degreaser works great. Spray on and wipe off. Follow with clear water because these cleaners are very strong and can etch the surface if left on too long.
Replace the cushion covers, carpet and curtains: no amount of cleaning will really help.
Fabreze also hepls after everything is really clean.
Many of the plastic parts will be yellow and/or smell. These can be cleaned in a mix of Clorox and water (50/50). A good 24 hour soak is neaded. NOTE: Some old plastic parts can become brittle and fall apart after the Clorox soak! Use this at your own risk.
After everything is is cleaned and the fabric is replaced you should be fine. If you're really sensitive you may still be able to smell the tobaco. Now you will nead to rent the ozone machine. These need to run from 24-48 hours to clear the trailer of tobaco smell. The ozone machine is the last step, not the first.
dlb435 is offline   Reply With Quote
Old 02-05-2010, 06:34 AM   #20
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Well you could burn it and start from scratch...
Or; I would hire a professional carpet cleaner for all the textiles anyway. They can clean the carpets, fuzzy walls, drapes, couch,etc...this would be a good start.Be sure they have experience with upholstery.
Yuk! Good luck...
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 02-11-2010, 06:09 PM   #21
1972 Travelux Princess 25
Cobourg , Ontario
Go easy with the ozone. It will age plastic, fabric, everything but metal.
Clean with your favorite cleaning product and water. Leave the doors and windows open to air out and you should be OK.
I like good ol' Spray Nine and microfibre cloths for cleaning. And a soft brush for getting into cracks.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Are You a Cigar Smoker? codybear Off Topic Forum 14 02-05-2013 08:34 PM
New Owner LHall Member Introductions 8 08-08-2007 04:14 PM
New Owner Bobz Hog Member Introductions 6 08-03-2007 05:27 PM
Another New Owner Alaska1966 Member Introductions 4 07-24-2007 07:01 AM
New owner mimibeth Member Introductions 2 06-10-2006 06:13 AM
