03-30-2007, 06:16 AM
1976 31' Sovereign
Charlotte
, North Carolina
Overhead 12 volt light switch knobs.
1973 AS Sovereign has all new overhead light fixture lens. Searching for a source or sources from which to purchase new knobs. OEM would be fine.
03-30-2007, 07:44 AM
1999 34' Excella
Joshua
switches..
Are you referring to the 3~position rocker switches? If so, then Billy Sims Airstream in Lubock has a lot of 1970-1980 stuff, talk to Dusty Sims.
History doesn't repeat itself, people do!
03-30-2007, 09:04 AM
Corona
The original screw on knobs for your Airstream ceiling light switches, have not been available for about 5 years.
03-30-2007, 07:14 PM
1976 31' Sovereign
Charlotte
, North Carolina
03-31-2007, 05:48 AM
1973 31' Sovereign
Danielsville
, Georgia
There is a 3 position rotary switch available at Lowe's for about $3.50 that will work. You will have to add a spacer to the switch mount (see pic) as the shaft on the replacement switch isn't as long as the original.
I did not keep the package but I believe it is Gardner Webb or something like that (red package). I compared it to the original and it seemed identical in specs. I've replaced all but one of mine (and I'm about to replace it soon).
03-31-2007, 08:40 AM
2008 27' Classic FB
1959 22' Flying Cloud
fairview
, New Mexico
I was able to get the original knobs for my 73 safari from Oasis rv in Tucson AZ a couple of years ago. In fact I also got a few of the switches.
03-31-2007, 10:53 AM
Jupiter
beware the amp ratings of the switches found in hardware stores - usually not meant for the draw of the 6-lamp overhead fixtures... calculate it out
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
04-01-2007, 08:28 AM
1975 23' Safari
1978 31' Excella 500
Franklin
, Indiana
I've used both hardware store switches and the Airstream supplied switch to replace mine. It's probably wise to heed the caution Wabbiteer offered to check the load rating.
Of the two types, the Airstream supplied switches were worth the extra effort and cost. They are very well made overall. They also turn in both directions so you can turn on just a low level of lighting and then turn it off without cycling through the other two positions. The hardware store switch I used only turned one direction.
The original part was manufactured by Cole-Hersey. I was unable to locate it on the internet, though it was available to order through a local Airstream dealer. The switch does not include the knob, but you can retrofit an old one if you have one.
I also took the time to replace the wiring for the entire lamp assembly while I had it down. I did away with the twist on connectors and replaced with butt-splice/heat shrink sealed connectors and marine grade tinned wire in a larger size than the original. I replaced the bullet connectors for the power and ground where they drop down from the ceiling so that I could easily remove the lamp/screen for cleaning. There's potential for moisture exposure up there. I had one corroded switch from my '78 that had gotten hot enough to melt the plastic (see pic).
Dallas Peak, MD 'That 70's Guy!'
VAC Past President
WBCCI #8481
04-01-2007, 07:01 PM
2002 25' Safari
Dewey
I just bought a new switch and knob for my 75 TW at Oasis RV in Tucson 2 days ago.....
Richard
04-03-2007, 06:54 AM
1973 31' Sovereign
Danielsville
, Georgia
Is this the original or replacement?
It must be stated from the outset here that I in no way desire to be part of or even worse, instigate a controversy on this or any other Airstream subject.
But.....
Below, in front of a Gardner Bender "hardware store switch", is a picture of a Leviton 4-position switch that was in my '73 Sovereign and it matches perfectly every single switch that I've replaced in both my '72 Overlander (3 ea) and the Sovereign (4 ea). I have always assumed that it was the original "factory" switch. (The Airstreams were both produced at Jackson Center but have lived, as far as I can tell, had two completely different lives.)
Am I wrong in my assumption? (Has anyone else found these switches in their Airstreams?)
Had my commercial electrician brother-in-law over last night and the issue came up. He examined the old Leviton switch and compared it to the Gardner Bender (hardware store switch). The amperage rating on the GB is twice what the Leviton was (3 amp @ 250vac, 6 amp @ 125vac vs 1 amp @ 250vac, 3 amp @ 125vac). (I knew this when I went shopping for it.)
His conclusion was that the GB switch was a lot safer than the Leviton, just from the amp rating alone. (It certainly runs a lot cooler, which is very noticeable to the touch.) The Leviton has been in there for years, I'm quite sure of that. And again, they were throughout my Overlander as well.
However, in an effort to be absolutely safe, we're going to put a meter up to it in the next week and test to see how many amps are being drawn with those 6 bulbs.
I'm all for OEM equipment when it is available, not too inconvenient, has no other acceptable market substitutions, and is reasonably priced. But like many forum members, I don't have an Airstream dealer accross the street from me. (The nearest one is 2 hours away.) And, like many "non-purists", I am looking for acceptable, safe solutions to 30 year old problems.
The energy conservation aspect of the Airstream switch is enticing (one rotation instead of three), but not really enough for me to go that far out of my way to purchase it. The modification required with the GB is a small inconvenience that I'm willing to bear. (After installing new Dexters this weekend, it seems extremely insignificant.)
My solution is not for everybody (proceed at your own risk), but one thing I do know is that the new switch is much safer (about 2 times) than what was there before. We will follow through with the current test within the next week and will post the results for anyone interested.
Pizzachop Photos
04-04-2007, 05:54 PM
1975 23' Safari
Franklin
, Indiana
Ron, thanks for your comments. I didn't mean to offend anyone's choices in switches. I've used the GB style switch's and they work. Not sure how the ratings for a certain amperage at 120v AC would translate over for DC, but I'm checking with my brother who's an electrical engineer to see if he can shed light on it.
The picture is a replacement switch from Airstream that I ordered through our local dealer in 2003. It's the same as the switches I've replaced out of 1972 and 1978 Airstreams. My 1972 had 3 black switches like Ron's in the lights covering vents and one like the Cole-Hersee in the light in the bedroom where there is no vent. I suspect someone had replaced the three others, possibly due to corrosion. They had also added a separate on/off toggle switch to each light supply. Possibly to allow you to leave them set at the first or second position and turn them off without cycling through each setting. I swear the rotary switches sometimes turn themselves on during travel! That would prevent battery discharge as a result of that, too.
I'll post what what my brother says about the AC/DC rating conversion.
VAC Past President
WBCCI #8481
04-04-2007, 06:20 PM
Central
, Mississippi
Cole Hersee specializes in distribution of stuff made by other folks so if someone does some searching and finds the 'real' source, let the rest of us know. Having spent several years in the manufacturing of switches and other electromechanical devices I can say the OEM is more than likely out of business and knock offs are coming from overseas!
Any one got a Cole Hersee catalog? I swear I had one several years ago.
04-04-2007, 08:12 PM
1973 31' Sovereign
Danielsville
, Georgia
Dallas,
No offense here. My brother-in-law and I had a lengthy discussion and the subject of direct current and its quirky amperage draws was a large part of it. (It's a much different animal from AC.) Again, we intend to put a meter to it to check just how much it is pulling with all 6 bulbs.
It is frustrating that a switch such as that cannot be had more easily.
As for all the switches I replaced, I would not be surprised if they had all been replaced. (But I wouldn't be surprised if they were the originals either.)
Good thing we don't sleep with the lights on!
04-05-2007, 10:04 AM
1975 23' Safari
Franklin
, Indiana
Look what I just stumbled onto at eBay! They must have seen our thread at "Out of Doors Mart"! Check out the detailed pictures. I seem to remember paying about ~$20-25 back in 2003. Do you mind telling us what you paid for them azflycaster?
Still have not heard from my brother on the AC/DC amp conversion.
VAC Past President
WBCCI #8481
04-05-2007, 10:09 AM
1971 27' Overlander
Central
, Ohio
I just purchased 3 last week from Airstream/delivered through the local dealer - they were either $11 or $12 each.
04-05-2007, 01:33 PM
1971 27' Overlander
Central
, Ohio
Correction on the above price - they were $9.56 each - no knob included of course.
04-05-2007, 05:22 PM
Venice
Another approach that gets around the problem of current capacity for switches is to add a 12V automotive relay. They are small (about 7/8" cube) and can handle plenty of power. Use the switch to run the relay (negligeable power) and the relay to operate the device (lamp, etc.) I've done this many times where I've wanted to keep an original equipment switch. No downside. The relay is easily and cheaply replaceable. What kills the switch is usually wear and dirt on the contacts that raises the resistance. This in turn causes heat which furhter increases resistance, and so on in a positive feedback loop that eventually ruins the switch and or the fixture or starts a fire. Modern cars use relays extensively because they use the computers to turn everything on and off. With a relay in the line your switches will never fail.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
04-05-2007, 08:10 PM
1975 23' Safari
Franklin
, Indiana
Here's the official electrical engineer's answer from my brother:
Dallas,
Glad to help, but have bad news. The design of the switch for AC and DC is different. Some switches are designed for both, and if so they carry a dual rating. If there is no DC rating, you should not use an AC switch in a DC circuit. It will fail to open the dc current, arc over, and can be a fire hazard. You remember that AC means alternating current, after a half cycle the current goes thru zero. With DC there are no current zeros. DC switches are harder to design/mfg than AC switches, and more expensive. You should be able to find a DC rated switch at W.W. Grainer.
VAC Past President
WBCCI #8481
04-05-2007, 08:23 PM
1973 31' Sovereign
Danielsville
, Georgia
Okay, that got my attention. (I think that was a more eloquent explanation of what my brother-in-law was concerned about regarding DC.)
I never thought of checking with Grainger, but they have just about everything else (except for a replacement for the FASCO kitchen exhaust motor).
04-05-2007, 08:25 PM
Another good place to find DC rated switches is RadioShack, and most Automotive stores.
Lots of rocker switches and toggle switches. A DC rotary switch will be harder to find. Grainger may be the last resort.
