Old 06-03-2014, 02:49 PM   #1
DJW
DJW's Avatar
2004 25' Safari
Lafayette , California
Over the stove vent and light hood
Hello All, not sure what sub-group this belongs in. I want to remove my stove hood unit and see if I can figure out an option to make it stick out less (bangs me in the face when I'm working at the stove).
Any tricks to removing it? Ducting to outside vent? Power connections? Hidden attaching screws?
Don
2004 Safari LS
DJW is offline   Reply With Quote
Old 06-04-2014, 08:46 AM   #2
DJW
DJW's Avatar
2004 25' Safari
I'll answer my own question, in case anyone every searches for the answer on this one-
Pulling the vent hood is pretty straight forward. Basically, 4 screws holding it to the cabinet, lift it off the back support bar, and it is free of the trailer. The two power wires need to be cut (they are crimped to the switch harness), but can be re-attached easily. I'm going to figure out a much lower profile vent hood which will make the space much more open and easy to work on as I use a cutting board on the stove top.
Don
Stove range hood vent leak frankiannell Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 02-05-2015 10:11 AM
Hood/hood lights and water heater stopped working!!! Thomas_G Electrical - Systems, Generators, Batteries & Solar 1 06-17-2013 12:49 PM
Remove the stove vent-hood for painting palmtreegirl Stoves, Ovens & Microwaves 0 07-27-2011 07:52 AM
Stove top/vent a hood rebel beck Stoves, Ovens & Microwaves 3 11-10-2005 06:27 AM
Stove vent hood Rob30044 Roof Vents, Skylights & Fans 3 08-27-2005 02:24 PM
