Old 12-28-2006, 05:51 PM   #29
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I used (and the factory did too) Vulkem in the wheel well. The photos you posted on either side of the well is where I put it, where the plastic well cover meets the metal outrigger. I'll have to look at the rest of my belly pan, I don't seem to recall my belly pan having that much of a gap, but who knows, it could be worse...haven't looked at it for a while.
Old 12-28-2006, 07:49 PM   #30
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Vulcum
Cool... I would rather use vulkem than the tape.Gonna go ahead and order some.Was there a certain type to get.I really dont know that much about the sealers.Thanks.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 12-28-2006, 07:55 PM   #31
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Call Vintage Trailer Supply and talk to them. I bought the white for the interior and grey for the exterior for my rebuild. Nice looking work, btw.
I'd keep an eye on those rivets. You did a great job repairing, now watch to see if anything else works loose under there. I wonder if maybe vibration caused it (out of balance or alignment wheel, low tire pressure, etc). It could also be that the factory just a poor job of attaching them in the first place.
www.nesa.org
Air No. 6427
Old 12-28-2006, 08:00 PM   #32
Devoman's Avatar
Rivets
Yea they pretty much fell out.I pulled them out with my fingers.Now they are really tight with the new ones in place.
I am going to order some probably in about a week.I will be off Camping all next week.
Old 12-28-2006, 08:12 PM   #33
Got gandkids?
Originally Posted by Devoman
........I will be off Camping all next week.
I think I heard something about that
www.nesa.org
Air No. 6427
Old 12-31-2006, 09:34 PM   #34
Devoman's Avatar
Steps
Are the steps connected to anything else instead of the 4 bolts?If I can get the stairs off I will be able to works on that open area a lot better.I am going to home depot tomorrow to find some rubber and some type of strong adhesive to seal it up.Not all the way tight but let just a tiny bit of an opening in case water gets in there from any future problems.Hopefully not mine though.
Old 02-08-2007, 02:59 PM   #35
Devoman's Avatar
Steps and hole
I just finished filling this hole up.I took the steps off and replaced the holes with some aluminum.All I used were an electric drill bit.Some wd40 on the drill drit.Some metal screws and Sikaflex.Man that stuff is hard to get out of that gun,and really sticky also.
Here is what I have done so far.
ID:	31983   Click image for larger version
Old 02-08-2007, 03:02 PM   #36
Devoman's Avatar
Aluminum
One thing though.Is this made of aluminum?Just wanting to make sure.I am going to take this paint off and polish it up to see how it turns out.If it works out good I will do the other one also.
ID:	31987   Click image for larger version
Old 02-08-2007, 03:03 PM   #37
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Devo- That looks pretty good. How come it's freezing here and I can't even go outside and your working on your AS! How unfair is that? Are you going to paint the inside black or leave it shinny? Looks pretty rodent proof to me.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-08-2007, 03:07 PM   #38
Devoman's Avatar
Paint
I think I am going to paint it grey to match the bottom as much as possible.Hope fully have it done by tomorrow.
The weather has let up and it has been around 65 to 70 degrees here.I have been wearing shorts the past couple of days.Hope you all up north get a good warm day here soon.You all have been getting hammered this year.
Old 02-08-2007, 07:04 PM   #39
Got gandkids?
Nice work, Devo. You'll appreciate this work even more a few years down the road.
www.nesa.org
Air No. 6427
Old 02-08-2007, 07:46 PM   #40
B4WEDI's Avatar
2006 19' Safari SE
Nawthin' , Hemisphere
I was looking at my gaps to the sides of the steps also........
I was thinking of using that styrafoam in the aerosol can. It will make a mess if I'm not careful, but the excess can be trimmed and painted black....
Anyone see a problem I may be overlooking using that product ?
Thanx for getting me off my keester on this one Devo. I am more concerned with rodents than water.
*** KEEP LOOKING UP ***
T & K
B4WEDI is offline   Reply With Quote
Old 02-09-2007, 02:28 PM   #41
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Put a magnet on it to see if it sticks. It could be steel, stainless steel or aluminum. Mine is unpainted stainless.
Dave
Fyrzowt is offline   Reply With Quote
Old 02-09-2007, 02:32 PM   #42
Devoman's Avatar
simple
Man...I did not even think about that.Gonna try it out.Either way I am going to find a way to mach the Airstream.one way or the other I will do something.Maybe even just purchase the stainless items to match.
Thanks.
Steps Opening And Closing For No Reason wb13798 Mechanics Corner - Engines, Transmission & More... 22 07-15-2005 06:06 PM
Door opening during travel... Safari Tim Doors & Locks 21 06-21-2003 08:16 AM
T/T Electric steps anyone? Excella3287 Steps 0 03-05-2003 12:27 PM
Steps Texas Steps 6 10-31-2002 10:50 PM
35 new pictures posted of 58 Traveler restoration williamhenshall 1958 Traveler 12 09-03-2002 10:08 PM
