10-17-2010, 07:36 AM
Certainly Blessed
1971 27' Overlander
Waiting to Escape....
, Somewhere between sanity and insanity ... on the brink of both.
Old Musty Smell
Our '71 Overlander has that old musty smell. Like a closet that hasn't been opened in 20 years smell. My husband says it's not so bad and that he can't smell it any more, but it drives me crazy when we first enter the trailer. It does get better the longer you are in there but I'm unsure if it's just my nose getting accustomed to it.
Here is some history:
the carpet is no more. We have a painted floor (oil based exterior grade). We did have to replace some sections of the floor in the front of the trailer.
new cushions and upholstery through out the trailer
every inch of the trailer (that can be reached without pulling out cabinets) was cleaned with orange oil and a black & decker battery operated scrub brush
no mold has been found, thus far, in the trailer
we found some indications of mice in the wheel wells on the door side and all that insulation has been ripped out.
10-17-2010, 07:59 AM
1974 Argosy 26
Morrill
, Nebraska
Odors
The PO was a smoker so I used "Simple Green". Sprayed it on in small areas full strength and rinsed with clean water. Made a big difference.
10-17-2010, 09:34 AM
_
the likelihood of removing this odor totally is zero.
1. the 'signature' 4 the particular smell is now RECORDED into your hardwiring (brain)
so you will never 4 get it and can easily recall it with even 1-2 molecules.
some folks have better memory/recording/recall and others not so much.
in the same way hearing, vision, color perception or touch vary from person2person.
2. the odor is IN the wood and in the insulation and in the plastics and so on...
while fabric and foams are easy to replace and might remove 75% of the smell,
it is PART of the stream and without a shell off resto using all new materials and media blasting of frame/shell...
it will return when the humidity or heat or air circulation is right.
__________
new paint, fabric, foam, floors and so on help a lot and COVERup with newer smelly things, but...
yer brain has recorded the musty signature and will eventually find it again.
__________
lots of folks praise using an ozone generator and they are effective.
they work best on brand NEW strong odors, like fire smoke or spills or a recently dead critter...
but 'ozone-ing away' a 20-30-40 year smell is not gonna happen, not completely.
search using the OH word in titles only or any of the other key terms (sm'L, must'E, and so on)
http://www.airforums.com/forums/f168...eams-2085.html
http://www.airforums.com/forums/f46/...dor-12330.html
http://www.airforums.com/forums/f125...odor-1378.html
http://www.airforums.com/forums/f431...odor-4612.html
also search using the oHzone term and many threads will be found with a lot of "it worked for me" testimonials...
http://www.airforums.com/forums/f431...ator-6484.html
a REAL o'z generator can NOT be used continuously/full time in an enclosed space without problems...
fabrics, plastics and others materials will breakdown when continuously exposed to Ozeee.
these gadgets are RENTABLE and if used for 2-3 days one can get wiff of effectiveness.
ymmv, the olfactory sense is 1 of our oldest and strongest and deepest brain functions...
IF the primary issue is being HIT with a wiff at entry, let someone else open the door.
cheers
2air'
10-17-2010, 09:49 AM
Jupiter
Ah, what'd I give to have "just" a musty old cottage or summer camp smell...
I started trying to kill smells in my '73 by carpet removal, painting the floor, pulling the bathroom and replacing the flooring there... trailer is now gutted with liners up and it still has a twinge of old formaldehyde - formic acid.
I found spills from galley ceiling lockers had run down under the kitchen counter top and found a spill of something in the pantry beside the refrigerator that was growing white crystals on the hidden edges of the shelves and aluminum frame.
Is the musty smell coming from the 'basement' where the fresh water tank is? A tiny leak in a vent tube or something long ago might've started a smell plus having a food spill nearby...
Okay, let's start some detective work looking for anywhere water vapor might've started regularly condensing out- ceiling lights and vents, have you dropped the lights and removed the screens and cleaned all those hidden areas?
Yes, there is a huge amount of surface area that is inaccessible. Have you cleaned or replaced the window screens? That is a high-surface area item. After reading your blog I'll ask did ya clean and paint behind/under the refrigerator?
I've read here an interior liner removal, change out of all the fiberglass insulation and washing the shell and hidden liner side is the only way to eliminate a mousy smell. I know, not what you needed to hear. Make 100% certain the vent stack pipes extend above the shell exterior and that the gaskets are in place is hyper-important. Andy claims the life of those rubber gaskets is only three years...
You can rent an ozone generator and leave the trailer closed up for a weekend with the thing on, open all lockers and access panels.
Ozone acts just like chlorine bleach so pull any dedicate fabrics, it will just brighten heavier ones. Having a small circulating fan on will help the ozone get to the hidden areas....
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
10-17-2010, 09:55 AM
x
XXXX
, XXXX
A lot of the smell will be in the insulation that is behind the walls. the pink fiberglass will absorb the smells of the last 39 yrs.
10-17-2010, 10:21 AM
1972 31' Sovereign
Lexington
I agree with Wasagachris, much of that odor is mouse related in your insulation. We had it until we gutted the trailer, and was completely gone once we got the old insulation out. The belly wrap was the worst, both for mouse and odor. We had apparently had quite the mouse infestation in our trailer at one time prior to our buying it - probably many years old as she had been neglected for many years before the PO bought her and started redoing some things. We even found a snake skin in the hot water heater!
That said, if it's not in your plans to do a gut job, you might want to try something on the ozone generator idea.
Kay
10-17-2010, 10:23 AM
1972 31' Sovereign
Lexington
Oh, and by the way, you might want to check all your propane connections. We had an odor in one of our trailers that I swore was dead mouse, and turned out to be a propane leak at the stove. Took awhile to track it down, until we got hold of a gas sniffer....
Kay
10-17-2010, 12:28 PM
Certainly Blessed
1971 27' Overlander
__________
So what you are saying is that if my sense of smell is particularly strong (and it can be) that even 1-2 molecules can call up the same strength of the smell?
10-17-2010, 12:38 PM
Certainly Blessed
1971 27' Overlander
Cottage smell is the perfect analogy.
We painted the floors under the gaucho, in the closet (shelves and floor), under the fridge (had to get a new one anyway), the shelves in the pantry. The only thing not painted was under the sink (nothing under there to paint) and the upper cabinets.
As for the rest, I am going to have to get my DH to check out the thread. he has a better idea of what's been done and where.
10-17-2010, 12:55 PM
1970 27' Overlander
Espanola
, Full Timer
We have that PEAK 03 Air purifier, and you better leave if you don't want to inhale ions. And they do bleach the air and just about everything else including bacteria, you name it. But it does leave the house smelling good and fresh.
10-17-2010, 01:58 PM
Certainly Blessed
1971 27' Overlander
Will have to live with the odor until next summer
Kay
If that's the case, we(being me) will have to deal with the odor until next summer. We have 3 big trips lined up in the next 5 months. Turkey-day, Christmas and Spring break are all booked. We need the trailer usable for all of these. Not to mention finding a space DH can do that work (our driveway's angle is not conductive for such work).
I think I'll try the smaller, easier to accomplish ideas and hope that it helps with the smell. If they don't work, then I'll move on to the bigger fixes....
10-17-2010, 02:04 PM
Certainly Blessed
1971 27' Overlander
According to DH, we have not cleaned all the screens. The screens over the actual windows are going to be replaced. The ones he tried to clean broke. He is going to check the exterior vent seals someday soon.
10-17-2010, 02:06 PM
Certainly Blessed
1971 27' Overlander
Kay
We have propane leak detectors...I am assuming that it will detect a leak.. we also had our local service guy check the LP system completely.
10-17-2010, 03:37 PM
1972 31' Sovereign
Lexington
Yeah, I wouldn't tackle the big things until I had exhausted all the others first, either! We just happened to be gutting ours anyway, but I do know how that smell can permeate everything! I'm glad the propane system is good. That one is more of a long shot when you describe the smell as "musty", but you can't be too careful with it either.
Kay
10-17-2010, 04:08 PM
Certainly Blessed
1971 27' Overlander
Dh is out in the stream right now. He is in the bathroom cleaning out old caulk/bleach water the creases/recaulking right now. He gonna smell real pretty when he comes inside!
11-16-2010, 06:26 PM
x
XXXX
, XXXX
I just discovered something weird today. I was using a heat gun inside the trailer to soften up some vulkem to remove it. The eau de Airstream was very apparent while heating the vulkem. Either the vulkem has absorbed the odors or it is the source of the odor. Any comments regarding this would be greatly appreciated.
11-16-2010, 07:18 PM
Certainly Blessed
1971 27' Overlander
Ours already had the fusty musty smell before Shawn resealed it...but that doesn't mean anything.
11-17-2010, 07:19 AM
2005 30' Land Yacht 30 SL
Rockford
, Michigan
like you that old musty smell drives me crazy! Here's a real simple trick I "discovered" when a mouse came into our basement to die. We couldn't find it anywhere. So, out of frustration I put 2 or 3 trays of bleach in the room. I used disposable plastic sandwich size containers & put about half an inch of Clorox in the bottom. The smell was mostly gone in 2 days, & totally gone by the time the bleach evaporated.
When we brought our MH home in May, I used this meathod again. This time for musty smells & moth ball overload. Don't ask me how it works, but it distroys bad odors. The air doesn't smell like bleach either, just smells clean.
11-17-2010, 04:30 PM
Sioux Falls
, South Dakota
I found this. I'm not sure what it means.
ozone_gen_fact_sheet-a.pdf
Gary
11-17-2010, 06:25 PM
1958 22' Flying Cloud
Folsom
There is a product you can buy at home depot by all the cleaning products called "odoban". It has succeded where other products have failed at removing odors like cigarrette smoke. That being said, it won't crawl inbetween walls.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
musty odor
Elaine and Bohdan |
Dehumidifiers & Ozone Generators |
20 |
12-08-2015 12:18 AM |
That Smell! I Know What It Is Now!
whitefawn |
Leaks - Weatherstrips, Gaskets, Caulks & Sealants |
12 |
03-09-2010 02:48 PM |
Smell!!!!
jim8860 |
General Motorhome Topics |
5 |
09-07-2005 06:59 PM |
Smell
garry |
General Interior Topics |
8 |
05-09-2005 07:31 PM |
What do you smell?
87MH |
Off Topic Forum |
27 |
07-24-2004 06:51 AM |
